2.5 YJ sputters / no start - JeepForum.com
post #1 of 2 Old 06-05-2011, 01:14 PM Thread Starter
seraph_rapture
So last night on the way back from my girlfriend's house my YJ started running like **** on the freeway. Bad sputters on acceleration meant that I had to keep it in 4th to maintain 55mph.
I nursed it back home at 30mph on back roads and when I pulled into my carport it barely idled with a lot of lope, then died. I tried to start it back up and it turns over, sounds like it wants to start, but doesn't.
So where should I start looking? I'm sure it's either fuel or spark...so here's my list of things to check...help me out with any suggestions.
Fuel pump
Coil
ECU
Plugged Cat
Lay some help my way guys.
It's a 92 YJ 2.5 AX5, 125k miles.
seraph_rapture is offline
post #2 of 2 Old 06-05-2011, 05:46 PM
hesserdude07
check your coil, then inspect plug wires, then fuel rail. My 2.5 use to do this every once in a blue moon.... regularly changed my plugs, and fuel filter. Sea foamed it like every 6,000 miles...
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
headgasket, now no start just sputters jimbo81587 TJ Wrangler Technical Forum 2 04-10-2011 09:07 PM
2.5 sputters and cuts off after start up cranberry33 YJ Wrangler Technical Forum 3 06-27-2008 05:39 PM
TJ occassionally sputters upon start up? MusicMaverick TJ Wrangler Technical Forum 5 11-21-2007 08:29 PM
Sputters in 4th and 5th blue1989yj YJ Wrangler Technical Forum 7 07-24-2006 07:31 PM
Sputters going from third to fifth? Synthisis YJ Wrangler Technical Forum 1 11-01-2004 10:17 AM
