2.5 YJ overheating - Page 3 - JeepForum.com
post #31 of 33 Old 01-02-2008, 11:26 AM
czjeeper
I just installed a 195 t-stat in mine to replace the PO's too cold t-stat.
Run it until it's hot with the radiator cap off, and "burp" the system by squeezing the upper hose. That should suck all the air out of the system.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #32 of 33 Old 02-24-2008, 06:25 AM Thread Starter
--chris--
--chris--'s Avatar
I thought i should update this thread with some important info on t-stats for out YJ's.
If you have to replace yours, make sure it has a bleeder hole!! I purchased 2 from advanced auto, neither of them had a breather hole (the factory one does!) and neither of them would open. They were the cause of this entire thread. I went to autozone, and the first one i picked up had a breather hole in it. I popped it in, and i never had another problem with it.
Save yourself some trouble, make sure your T-stat has a breather hole on it!
--chris-- is offline
post #33 of 33 Old 12-06-2009, 07:15 PM
buzziegee
2 things you could do....1 drill a 3/32" hole in the stat,that should get rid of any air lock in the system,or ,this is a bit extreme(depending on the climate),,you could gut the stat so its a restriction(this is a common low buck drag race trick).Just remove the valve/spring assembly,it should leave you about a 3/4 to1 inch orifice so the coolant will absorb the heat in the block/head,but it will take a little longer to get some heat...but try the 3/32 hole first ,,that should do it....Buzziegee
buzziegee is offline
overheating? attackcammel TJ Wrangler Technical Forum 7 07-04-2010 11:58 AM
overheating? Mudzilla6661 Wrangler General Discussion 8 08-15-2009 08:33 PM
overheating 87 danthman YJ Wrangler Technical Forum 6 03-05-2009 06:44 AM
overheating, only at 55+mph ...? TXjeepTJ TJ Wrangler Technical Forum 7 09-19-2007 07:55 AM
Overheating Kel Dub TJ Wrangler Technical Forum 7 01-21-2006 02:25 PM
