Quantcast 2.5 will crank no start please help. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 2.5 will crank no start please help.
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 07-08-2008, 11:55 AM   #1
Bigboyky
I've been having problems starting when cold. I thought I had it fixed after a new fuel pump, filter and pressure regulator. But yesterday while running around 60mph down the interstate the motor died. I've checked the relay, by putting the horn relay in it's spot. Numbers all matched. I pulled the pump again but it's running fine. I couldn't hear it in the tank. I'm getting voltage from the #6 pin on the ECU. I've looked at the only schematics I have and the only things I can see the might be holding me out is the EGR/Canister purge solinoid & the B+ Latch Relay. Where is the purge solinoid located? The book says front left of shock tower but I sure didn't see it.... Any other ideas? Please help and sorry for the long post.
Bigboyky is offline   Reply With Quote
Old 07-08-2008, 01:25 PM   #2
Jeeeeeeeeeeeeep
Have you checked for a good signal from the Crank Position sensor?
Jeeeeeeeeeeeeep is offline   Reply With Quote
Old 07-08-2008, 02:04 PM   #3
Bigboyky
Where's that one at?
I'm getting spark just nothing at the fuel pump. I put a multi meter on the fuel pump connection at the tank, no voltage. I'm lost here.......
Old 07-08-2008, 02:16 PM   #4
lespaul_custom
could be a corroded wire, had and issue once with my jeep, it would run great one day then cut off while driving, found that it was a corroded connection where the fuel pump hooks up to the wire harness...could wiggle it and make the jeep die, anyways used some butt connecters and shrink tube and fixed the prob....check to see if you got voltage on the wire harness side of the connecter. good luck man
originally posted by urb4ntroll
The weird thing is that I thought I hear a minor bang, almost like a fart sound coming out of my Jeep, but I'm not sure what it was. It has never happened before the glue incident.
www.coosa.org white jeep club #1993 looking to buy complete rear seat belts
lespaul_custom is offline   Reply With Quote
Old 07-08-2008, 03:44 PM   #5
Bigboyky
Just went through all wiring from the pump back to the power distribution box then over to the ECM no luck. Have tried going through the senors but need to know which ones would keep the fuel pump from running.
Old 07-08-2008, 08:47 PM   #6
Bigboyky
Need more help here. I've spent all day working on my jeep. I have no spark and no fuel. The crank position sensor was found to be bad, new one didn't change much. I then started looking at spark. Yesterday (monday) I saw a spark on the side of the road, now there isn't a spark. The rotor button was screwed up the contact that goes to each pug was sideways and burnt up. Placed a new one on still no spark. Still no voltage at the fuel pump either. Is my PCM dead? What does the PCM cost?
Old 07-09-2008, 07:51 AM   #7
Bigboyky
bump for more help
Old 07-09-2008, 08:18 AM   #8
BUDMAN88
1 more beer
Have you check all the fuses after all that work? Check wiring harness connection at the fire wall.
BUDMAN88 is offline   Reply With Quote
Old 07-09-2008, 08:47 AM   #9
Bigboyky
double checked fuses. never took the firewall connection apart but it seems tight.
Old 07-09-2008, 09:01 AM   #10
Bigboyky
Anybody know if the camshaft sensor will keep it from firing? Or how to test the cam sensor? I can't find a test for it.
Old 07-09-2008, 11:59 AM   #11
1995_4.5L Jeep
On my 1995 4.0L I found the wire from the fuel pump relay had come lose under the fuse box. I think it's a green wire with a red stripe. My jeep would shut down after hitting a bump, and often wouldn't start cold or hot.
1995 Wrangler 4.5L
8.8 Ford rear
4.11 gears
ax-15 trans
4" lift 33" tires
1995_4.5L Jeep is offline   Reply With Quote
Old 07-09-2008, 06:09 PM   #12
Bigboyky
Well I broke down and took it to the Stealership.......... I was out of ideas. I'll let you know what comes of it. My backside is already hurting....
Old 07-10-2008, 09:37 AM   #13
Bigboyky
Problem.... I just heard from the stealership. They are saying the computer is bad imagine that. At 700 to repair. What do you all think?
Old 07-10-2008, 10:10 AM   #14
1995_4.5L Jeep
This will work. http://cgi.ebay.com/ebaymotors/Jeep-Wrangle-2-5L-ENGINE-ECU-ECM-COMPUTER-1991_W0QQcmdZViewItemQQcategoryZ33596QQihZ012QQite mZ220254763302QQrdZ1QQsspagenameZWDVW
It's the wrong year, but when my ECU died I replaced mine from a 1992
1995 Wrangler 4.5L
8.8 Ford rear
4.11 gears
ax-15 trans
4" lift 33" tires
Old 07-10-2008, 10:51 AM   #15
Bigboyky
They told me I can't use a used one due to the fact they have to program it either way.... Anybody else have to deal with this?
Glock Forum
