Quantcast 2.5 wants to start but stalls!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 2.5 wants to start but stalls!!
Spartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-RoadBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 09-14-2009, 09:55 AM   #1
Roadster72
Junior Member
Hey guys. New to the world of jeep. just bought a yj on criagslist at a steal. My odometer wasnt working so i did so research and found it there was a plug on the transfer case that some times gets dirty. so i pulled the plug and cleaned it with some contact cleaner. didnt work. pulled the whole gear and all to check it wan looked great. put it back and it didnt want to start. used a test light to check to see if it was getting power and heard what sounded like the fuel pump kick on. prior to all this it ran great. pulled the plug on the transfer case and it started up again put the plug back on and it still ran fine. later that night i started it up and it ran for a couple of min and stalled but started back up. drove it about a mile home and stalled and wouldnt start again. checked the fuel rail and am getting fuel and hear the pump kick on. im trying to figure out if maybe i blew a sensor or the ecm ecu. any ideas.
Thanks
Dom
92 YJ
Roadster72 is offline   Reply With Quote
Old 09-14-2009, 10:03 AM   #2
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Sounds like you need to run the codes test: OBDI Error/Check Engine Codes - JeepForum.com Community Jeep Wiki
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 09-14-2009, 10:05 AM   #3
Louie4
Injanir
Louie4's Avatar
See if you can get any codes out of it. Just turn the key On-Off, On-off, On. Count the flashes and see what happens.
Check this out on post #6 and 7.
http://www.jeepforum.com/forum/f12/frequently-asked-questions-faq-your-answers-usually-here-451154/
Lou
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is online now   Reply With Quote
Old 09-14-2009, 10:31 AM   #4
Roadster72
Junior Member
ok checked the codes. im getting a 12 and a 33 and a 55 which i believe is the end of the codes. from what im reading there is no 12 and 33 is Air conditioning clutch relay, in which case i dont have any ac unit. so now im even more lost lol. these are the codes i found online at Jeep Horizons :: 1991-1995 Jeep Wrangler (YJ) Trouble Codes
11
Ignition
13
Manifold Absolute Pressure (MAP) Sensor Vacuum
14
Manifold Absolute Pressure (MAP) Sensor Electrical
15
Distance sensor or circuit
17
Engine running too cool
21
Oxygen sensor or circuit
22
Coolant temperature sensor or circuit
23
MAT sensor or circuit
24
Throttle Position Sensor (TPS) sensor or circuit
25
Automatic Idle Speed (AIS) circuit
27
Fuel injector control
31
EVAP solenoid or circuit
33
41
Alternator field
42
Automatic shutdown relay
44
Battery temperature sensor
46
Battery over voltage
47
Battery under voltage
51
Oxygen sensor - lean condition
52
Oxygen sensor - rich condition
53
Internal engine controller fault
54
Distributor sync pickup
55
End of Code output
62
Emissions Maintenance Reminder (EMR) mileage accumulator
63
Controller failure EEPROM write denied
Old 09-14-2009, 11:22 AM   #5
Mean Max
Mean Max's Avatar
This sounds like a case of a bad ASD relay (Auto Shut Down relay) located in the PDC. Usually, a bad ASD will cause it to start, then immediately stall. It's a standard 5-prong relay.
PDC - Power Distribution Center
Relays - The ASD relay is the center black relay in my '91 PDC. Refer to the diagram under the lid to make sure you know which one is the ASD on your YJ.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 09-14-2009, 12:06 PM   #6
Roadster72
Junior Member
Thank you all for your help but it seems that the major problem was very minor and dumb. i checked to see if i was getting good spark and it was intermittent. so i then checked the plug for the coil which has the little lock broken off. pulled it out then pushed it in and wal la it works find. gonna find a rubber band to hole it in better. why is it the stupid little things that piss ya off the most lol.
Dom
Old 09-20-2009, 10:00 PM   #7
loverocks4013
Mean Max.....the codes I got were one for the AC which I don't have and the other was for the EGR System?? I am going to look this up...but when you get this can you give me some assistance? Thanks so much
~ Love Rocks ~
loverocks4013 is offline   Reply With Quote
Old 09-20-2009, 10:55 PM   #8
idaholtby
#12 just means that the battery was disconnected sometime within the last 50 starts. Nothing to worry about and is a normal code to have stored. It does not cause the CEL lamp to light. Glad to here you got it fixed!
Also, your '92 does not have an EGR system. It has a CCV (Crank Case Ventilation) which relies on a three-way catalytic convertor to knock down the NOx emissions.
idaholtby is offline   Reply With Quote
Old 09-20-2009, 11:08 PM   #9
loverocks4013
Idaholtby...are you referring to me?? and my 1993 ACtually I think its my ignition switch...well I hope so anyway...lol
~ Love Rocks ~
Glock Forum
