2.5 is VERY underpowered... What more can I do? - Page 5 - JeepForum.com
Closed Thread
post #61 of 75 Old 10-24-2011, 11:09 PM
ashland82391
Out of money yet...Yup!
ashland82391's Avatar
Originally Posted by jonzjeepyj View Post
I have done that also. What tire size are you running or want to run?
I am running 31x10.5x15 and plan to stay there doe to the cost of larger tires.
ashland82391 is offline
post #62 of 75 Old 10-24-2011, 11:19 PM
moonshinefuel
The 2.5 may be an under powered dog for the street, but for crawling, its all about gearing
http://www.jeepforum.com/forum/f176/...j-fan-1180112/
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #63 of 75 Old 10-24-2011, 11:44 PM
jonzjeepyj
I have run many set ups with many tire sizes with many gear ratios. For 31's
with a 2.5L and a 5 speed stick, your best gearing is 4.88's I absolutely loved
that combo. It ran very well with plenty of power in all 5 gears.
There is no problem that can't be fixed if you throw enough money at it.
jonzjeepyj is offline
post #64 of 75 Old 10-24-2011, 11:48 PM
ashland82391
Im a new jeep owner so forgive me but how would I go about converting to 4.88s? Is the gearing in the axles or trans? How much does it cost?
post #65 of 75 Old 10-24-2011, 11:54 PM
jonzjeepyj
You must re gear the axles
Cost is . . . . .
1) Gear Set / Ring and pinion - $145.00 each set
2) Master install kit - $80.00 each set
3) Someone to set up and install them - $200 -TO- $400.00 per axle
4) Average cost is $500.00 -to-$600.00 per axle
5) $1000.00 -to- $1200.00 total cost
post #66 of 75 Old 10-25-2011, 12:00 AM
Xpress
I liked the way my YJ drove with 31's and stock gears. It might have been a bit sluggish to get up and go, but it drove very well. I'd like to think that 3200rpm and 50mph is reasonable in 3rd gear.
Probably very easily could have benefited from the e-fan upgrade and maybe even a 4.0 throttle body, 19lb injector and a throttle body spacer- all stuff you can pickup for cheap if you use the junkyard. Besides, the way I see it, Jeeps are a VERY personal thing so put whatever you want to put into it. As long as it makes you happy, who ****ing cares about what others think? 10-15hp is all that engine needs to do well everywhere with larger tires.
All about that unibody life.
Xpress is offline
post #67 of 75 Old 10-25-2011, 12:03 AM
ashland82391
Cost is . . . . .
Wow thank you for the information! i have some pretty mechanically savy family members so I wont have to worry about install $, so about 450$. Do you know what gear ratio is in a stock 93 jeep yj? Would this make a difference in gas? And would the offrading capabilities be compremised?
post #68 of 75 Old 10-25-2011, 12:13 AM
kyle_craig
Re-gearing is the only thing that will make you happy. I say start ordering parts. Your Dana 35 will be fine with 31s unless you are absolutely brutalizing it. Put some 4.88 gears in the axles and it will feel like a hot rod compared to your factory 4.10 gears. The 2.5L needs to be at 3000 revs to make power/maintain speed on an incline. As far as off-road capability, your low range will be even slower because of the re-gear. This is a good thing because once again, the engine needs higher revs to make power.
On a side note, I run 4.88s with 35s and maintain 60 mph in 3rd up any mountain pass in Colorado. It will also hold 5th gear going 80 on flat freeway with ease. I consistently get 18 mpg with 35s...I'd imagine with smaller tires it could be even better.
kyle_craig is offline
post #69 of 75 Old 10-25-2011, 12:17 AM
ashland82391
On a side note, I run 4.88s with 35s and maintain 60 mph in 3rd up any mountain pass in Colorado. It will also hold 5th gear going 80 on flat freeway. I consistently get 18 mpg with 35s...I'd imagine with smaller tires it could be even better.
thanks alot
post #70 of 75 Old 10-25-2011, 12:18 AM
jonzjeepyj
X2 Right on the money !
post #71 of 75 Old 10-25-2011, 12:20 AM
nembudonna
Every buddy look. A 4cyl will never be as fast as a 6cyl, and a 6cyl will never be as fast as an 8cyl. But when I'am in my jeep with my best friend Hooter, I'am in no hurry to get there. End of thread.
nembudonna is offline
post #72 of 75 Old 10-25-2011, 12:21 AM
ashland82391
I have one more question. What is the master install kit? Is that the correct name for it? Is there any othere information I need to know about it when looking it up for puchase?
post #73 of 75 Old 10-25-2011, 12:34 AM
jonzjeepyj
It has the shims, seals and gaskets to install the Ring and pinion gear sets.
Yes, that's what it is called a Master Install Kit.
post #74 of 75 Old 10-25-2011, 12:45 AM
ashland82391
thanks alot guys you really saved me alot of research! Is there anything else you think I should no before diving into this project? And do you guys know anything about a 2.4L 4 banger in the yj's?
post #75 of 75 Old 10-25-2011, 01:03 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Stop while you're ahead.
Go back & read the entire thread. Pay close attention to those who have been there & done that.
Then start another thread if you still don't know.
Too much running of the mouth goin' on in here.
closed for now.
Joe Dillard is offline
Closed Thread
2.5 , power , YJ
Automatic Underpowered on Rubicon ?? leopardprey TJ Wrangler Technical Forum 11 05-24-2005 08:58 AM
