2.5 is VERY underpowered... What more can I do? - Page 2 - JeepForum.com
Closed Thread
post #16 of 75 Old 10-23-2011, 04:43 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Remove the 2.5/AX5 POS and place here...
Been there and done it. By the time you screw around with the 2.5, the AX5 will take a dump. By the time you fix that, it will be back to feeling slow and then you will spend a fortune regearing the axles. Then the Dana turdy5 will go boom, and it continues.....
Grab a S10 blazer and a Ford 8.8 and swap teh motor/tranny/transfer case and rear axle and do it right.
Or sell it and buy a 4.0 YJ.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #17 of 75 Old 10-23-2011, 04:50 PM
johnny27030
Originally Posted by firstnationslw View Post
Are you sporting a hard or soft top? I think my hard top doesn't help matters but I'm in northern Vermont... hard tops are a necessity during northern winters.
Im running a soft top. Would love to find a hard top for the winter though
johnny27030 is offline
post #18 of 75 Old 10-23-2011, 05:01 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Attachment 294405
Martin
This. There really is no economic way to increase HP on the 2.5L. Even if you do, the AX-5 is the next weak link, followed by the rear end.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #19 of 75 Old 10-23-2011, 05:14 PM
jonzjeepyj
I agree that a motor swap is a much better power upgrade but the cost for
me to do swap my motor was completely unrealistic. I just couldn't afford
it. All of the 2.5L motor mods only cost me around $325.00, $200.00 of it
being the super coil and live wires. A motor swap would be in the thousands
of dollars to complete which just wasn't an option for me. For most of us,
it's about making the most of what we have and can afford. After all the mods
were completed on my little 2.5L YJ, it really had some pep with a lot higher
top end. No it will never be a 4.0L powerhouse but after doing all of the mods,
it preformed so much better. The Jeep had a smoother idol, more off the line
pep and would pull harder all the way through the power band. Now instead of
topping out and running out of power at 3800 rpms, it now accelerates and pulls
hard all the way through 5200 rpms. What a huge Improvement!
There is no problem that can't be fixed if you throw enough money at it.
jonzjeepyj is offline
post #20 of 75 Old 10-23-2011, 05:40 PM
little_Jeep
Originally Posted by jonzjeepyj View Post
There is no problem that can't be fixed if you throw enough money at it..... EXCEPT THE 2.5L
Fixed it for you.....
little_Jeep is offline
post #21 of 75 Old 10-23-2011, 06:09 PM
94chb
94chb is offline
post #22 of 75 Old 10-23-2011, 06:19 PM
little_Jeep
Originally Posted by 94chb View Post
So how long does the AX-5 and/or the D35 last once the turbo is in place?
post #23 of 75 Old 10-23-2011, 06:25 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
From the website:
The base $2,999 kit includes...
You can just stop right there. $3k to polish a turd? Then you're still fighting reliability from the transmission and rear end, now adding a turbo stock engine on top of that.
For $3k you can have a v8 with a stronger transmission AND rear end.
-Matt
White '94 YJ Sport
UltimatE is offline
post #24 of 75 Old 10-23-2011, 06:30 PM
leftlanetruckin
XJ on 37's
Oh oh, the "the magazines did it, so it must be right" portion of the thread...
Over the years, magazines have loved stuff, then hated it a year later.
I have personally read in JP them saying the 2.5 is a POS, and get a 4.0. Far too many times for me to believe every word they say about making the 2.5 better.
Make a bet with someone.....I bet I can swap a 4.3/700r4/8.8 into a YJ for less money than a turbo setup done right. Now remember you have to make the weak AX5/dana turdy5 last too
Martin
post #25 of 75 Old 10-23-2011, 06:34 PM
jonzjeepyj
I'm personally doing a 4.0L swap. I found a 99 XJ with 96,000 miles on it as a
donor vehicle. It has the 4.0L Motor, AX-15 5-speed manual and the 31 spline
N-231-J T-Case, I bought the whole vehicle for $800.00. This way I can use
the wire harness, ECU, Alt, Starter, Rad etc etc . . . . I ran my little 2.5L motor
while I built my rig. I now want to upgrade the motor. I had to save and watch
for a deal to come along. I will be putting it in the weekend of Nov 7th.
I agree hands down that a motor swap it's a much better way to go
as I'm doing one now but talking from experence, I know what the 2.5L
motor is capable of. When all the upgraded mods are done together along with
re-gearing the axles, that little 2.5L Low Output Motor does just fine,
post #26 of 75 Old 10-23-2011, 06:38 PM
mazyj
First check everything out and make sure the engine is in fact running correctly- it sounds like it is though. If it is running correctly either get used to it, make friends with downshifting, or save money for a engine swap or new jeep. You can throw hundreds of dollars at a 2.5L and still be slow as hell. For the price you paid on the upgraded parts for the 2.5L you could have grabbed an engine from a junkyard and been on your way...
The 2.5L is a reliable motor and a Jeep is still awesome either way, either get used to it and enjoy it, or get a different motor. Otherwise your wasting your time and money and that's no fun.
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
post #27 of 75 Old 10-23-2011, 06:50 PM
jonzjeepyj
Remember, all my upgrades together were only $125.00. I decided to also go
with the super coil and live wire combo for an additional $199.99. It wasn't
necessary but was an upgrade I wanted to do. I personally wouldn't do the
Turbo upgrade. To me the cost doesn't outweigh the benefit. Most of the
upgrades I did were either Free or very low dollar.
post #28 of 75 Old 10-23-2011, 08:00 PM
Xpress
There's a reason why the 2.5L is known as the iron brute and it's NOT because it's a pos . FWIW I think just upgrading to an electric fan would be enough to free up robbed horsepower, not to mention it would quiet the ride down. Ideally, you would only need 5-10hp at the most to get enough power.
Another thing:
IT'S A JEEP not some high speed sports car. With this theory in mind, I have no troubles driving highways. Why I was actually running a bit late to work this morning and I had no problems running at 75mph mostly the entire 6 mile freeway trip. Got there right on time.
All about that unibody life.
Xpress is offline
post #29 of 75 Old 10-23-2011, 08:07 PM
moonshinefuel
There's not much you can do with the 2.5 power-wise. It's a good engine, but not your highway hill climber. I have no complaints with mine as I accept it as it is. Obviously a 4.0 is more powerful with a better transmission. But, jeeps can, and are built, and altered all the time. Quick fix is the 4.0. But for me, point a, to point b, is my primary concern, and my 2.5 has done this for me for many years. I just live with the fact that fully loaded semi trucks pass me going up steep highway hills. Other than that, it does just fine. To me, a small price to pay. I just bought an 8.8, and have an nv3550. Basically, this sets the ground work for a future V-8 swap if I choose.
So basically, live with it, and build it over time, or sell it and buy a 4.0. Either way is fine. It's all up to you.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #30 of 75 Old 10-23-2011, 08:27 PM
Old4X
1990 CJ7
The 4 popper matches the military Jeep's powerplant fairly well. It has decent offroad power, and has no problems at all keeping up with military highway convoys. Thing is, military convoy speed limit is 50 MILES PER HOUR!
The YJ with a 4 popper is the perfect chick car for a high school cheerleader. Lots of flash, but no go, it is in the same league as a Mustang with a 4 popper. It is mostly a styling ride with good looks.
Sell what you have (to some HS girl) and get a 4.0 HO equipped Jeep. If you want something with some real go, get one that has had a V-8 installed along with some beefier axles.
AS most have mentioned, you will NEVER get a 4 popper in a YJ to perform. And you will notice that no one that claims their 2.5 was improved by spending money on it can seem to find a dynamometer to back up their claims.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
Closed Thread
2.5 , power , YJ
Automatic Underpowered on Rubicon ?? leopardprey TJ Wrangler Technical Forum 11 05-24-2005 07:58 AM
