2.5 vacuum line questions! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 2.5 vacuum line questions!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 08-11-2012, 10:28 PM   #1
sxi4evr
just rebuilt the 2.5 got it in and i'm not sure if i have all the vacuum lines hooked up right on the intake... what would be absolutely the most helpful is if someone could take a pic of where all the lines hook up and label where they go
also, same thing on the valve cover. i'm pretty sure the po changed things around here...but again idk.. i have an evap canister at the rear of the cover (which autozone says doesnt exist for my jeep and ive never seen another jeep with one) that connects to the air box. seems fine but isn't that supposed to be a pcv? and just a nipple at the front which i THINK was just venting?
ALSO, the nipple coming into the fuel pressure regulator, that's a vent. correct?
forgive me if i make no sense, i've been wrenching since this morning and my brain is fried on the subject
Check out my YJ!!!! http://www.jeepforum.com/forum/f22/first-timer-yj-build-1373716/
sxi4evr is offline   Reply With Quote Quick reply to this message
Unread 08-11-2012, 10:58 PM   #2
pete1991YJ
pete1991YJ's Avatar
Both the line on front of the valve cover, and the fuel regulator nipple , *NEED* to be hooked up straight to manifold vacuum... or else it'll run like crap too rich, and puke oil all over the place. Factory is somewhere directly underneath the throttle body. There should be a few ports to choose from, down there. Hope that helps...
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline   Reply With Quote Quick reply to this message
Unread 08-11-2012, 11:09 PM   #3
sxi4evr
very helpful, thank you!
