2.5 Stroker, anyone run one? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 2.5 Stroker, anyone run one?
The Original 3/8" Ruffstuff Diff Cover!Building a Bumper?Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-23-2012, 08:11 PM   #1
Overhead
You built a 4cyl?
Overhead's Avatar
My 2.5l in my 95 bit the bullet, looking to drop in a stroker with some upgrades (inertia ring 4.0TB ect ect) anyone know someone who has one and likes it? Already hearing the chorus of Just drop a 4.0 into it and you'll be happier, but I'm pretty set on sticking with the 2.5 as the base motor. Though every search I do for any info on a 2.5 stroker comes up with either nothing or A friend of a Friend who knows one. I like being different, but theres a limit, just looking to know if anyone else runs one thanks!
Overhead is online now   Reply With Quote
Unread 07-23-2012, 08:17 PM   #2
Jakes89Wrangler
http://www.jeepforum.com/forum/f180/...troker-380800/
from what I read there, you would be wasting time and money.
Jakes89Wrangler is offline   Reply With Quote
Unread 07-23-2012, 08:28 PM   #3
Nickabis
Here's a link to a guy doing the 505 build on a different site.
http://www.wranglerforum.com/f8/2-9-...up-175544.html
I've been looking but that's too expensive for me. I like my 4 cylinder so I'm going to swap in the multi port motor, add e fan, injector and 4.0 throttle body, and a mopar performance cam I acquired. I'll also re-gear.
Nickabis is offline   Reply With Quote
Unread 07-23-2012, 10:04 PM   #4
Overhead
You built a 4cyl?
Overhead's Avatar
I searched, and couldn't find it, thanks! the plan is to add an efan and a all the little upgrades at the same time
EDIT: those links only show the idea, nothing completed with numbers and a final product, anyone?
Unread 07-23-2012, 11:17 PM   #5
ltrail
1984 XJ Cherokee
Frankenstein one together. I toyed with volvo for a while and with some Mitsubishi evo rods, and some SBC pistons, and some crankshaft machine work your 2.3 was between 2.5 and 2.7. Saw some 3.1l setups but that was pushing the Limits of the cylinder walls.
Zealautowerks.com has a compression calc that is helpful. You enter bore, stroke, deck height, rod length, etc. It will spit out a compression ratio, displacement, piston speed, and bore/stroke ratio. Good for playing around with such ideas.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline   Reply With Quote
Unread 07-24-2012, 08:56 AM   #6
Overhead
You built a 4cyl?
Overhead's Avatar
I'm talking with a machine shop the has alot of experience stroking things, but the have never done a 2.5. theres a warranty on the engine if I do through them to rebuild/stroke it and the price between the two is not much different. I know it's not something that's done alot but is it done at all?
Unread 07-24-2012, 09:30 AM   #7
ThomasYJ
What about rebuild and then boost it? That's been done before.
ΜΟΛΩΝ ΛΑΒΕ
If you can't be safe be deadly.
We are what we repeatedly do. Therefore, Excellence isn't an act but a habit.
ThomasYJ is offline   Reply With Quote
Unread 07-24-2012, 05:04 PM   #8
Overhead
You built a 4cyl?
Overhead's Avatar
Thats another option, as opposed to full on stroking it, just adding some extras to beef it up.
Unread 07-24-2012, 05:40 PM   #9
ThomasYJ
Yeah I'm sure all the bolt son's will only benefit. Plus have you considered over-boring as well?
ΜΟΛΩΝ ΛΑΒΕ
Unread 07-24-2012, 07:07 PM   #10
Xpress
Sounds like it's more than a fun enough project to do. I've read rumors of the kit putting out around 140 hp to the rear wheels, which to me is quite worth the investment without having to overhaul the entire Jeep. Really all you need to do (aside from the kit) is fit a better transmission that can handle the power, and you still have the lightweight and relatively fuel efficient 4 cylinder engine that makes 4 cylinder Jeeps so good on the trails.
[url=http://www.jeepforum.com/forum/f12/another-5-2l-yj-thread-1503048/][FONT="Arial Black"][COLOR="Lime"][SIZE="4"]My 5.2L Build thread[/SIZE][/COLOR][/FONT][/url]
-1989 Jeep Wrangler 2.5L, soon to be 5.2L
-1996 Jeep Grand Cherokar 5.2L, donor and rainy day driver
-2004 Kawasaki KLR650 sunny day driver
[QUOTE=mudsweatNgearz;21162729]Leave em off and weld an I beam on. Bumperetts just scream homo.[/QUOTE]
"A well regulated Militia, being necessary to the security of a free State, the [B][I]RIGHT[/I][/B] of the people to keep and bear Arms, [B][I]SHALL NOT BE INFRINGED[/I][/B]."
Xpress is offline   Reply With Quote
Unread 07-24-2012, 11:03 PM   #11
Overhead
You built a 4cyl?
Overhead's Avatar
the trans has been fixed up a bit, and was gonna add in an inertia ring to keep that power moving, if I go stroker its down for probably 6 months to fix all the things I need to fix on it and that list could go on for hours, but also prep it to keep the new motor running well. still no clue at all about what I'm gonna do but that is the tentative plan to have it running by the new year
Unread 07-25-2012, 12:01 AM   #12
ltrail
1984 XJ Cherokee
find a core to build so limited down time.
Unread 07-28-2012, 08:55 PM   #13
Overhead
You built a 4cyl?
Overhead's Avatar
so after all the research and options and investigation, I'm gonna build a stroker. I'll do a write up on all that it's gonna take and what not. thanks!
Unread 10-04-2012, 06:17 PM   #14
ThomasYJ
progress report???
ΜΟΛΩΝ ΛΑΒΕ
Unread 10-08-2012, 11:41 AM   #15
Overhead
You built a 4cyl?
Overhead's Avatar
Originally Posted by ThomasYJ View Post
progress report???
Muhahahaha End of the month it goes into the machine shop for a complete rebuild and stroke. Will post up when I've got final specs but looking at right around 200hp. added alot of extras to support it, vented fenders, hood louver, e fan and all the like.
