2.5 sputters, hesitates while accelerating - JeepForum.com
post #1 of 36 Old 04-13-2011, 06:20 PM Thread Starter
InEmberClad
Hey all,
So my heep has been acting a little weird. All I can tell you that I know is wrong with it is that the clutch slave is in need of replacement. Not sure if this could cause it to behave the way it is though.
Only happens sometimes, but lately when I'm accelerating in first from a dead stop or getting up to around 2000 in second it sputters and hesitates a lot. To get it up to speed usually I need to be in third which is not ideal.
Fuel injector is 1 year old almost exactly and the fuel filter has been replaced within a couple months along with plugs and oil. Any thoughts?
InEmberClad is offline
post #2 of 36 Old 04-13-2011, 06:30 PM
oldtime_ironman
Throttle position sensor (TPS) comes to mind
oldtime_ironman is offline
post #3 of 36 Old 04-13-2011, 06:39 PM
moonshinefuel
Outside chance of a failing fuel pump, testing fuel pressure might not be a bad idea.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #4 of 36 Old 04-13-2011, 06:47 PM
oldtime_ironman
x2 on the fuel pump too... ask me how I know!
post #5 of 36 Old 04-14-2011, 10:30 AM
Que89YJ
Does it matter if the engine is cold or warm?
Que89YJ is offline
post #6 of 36 Old 04-14-2011, 10:48 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Check your intake manifold bolts and gasket. My bolts loosened up and sucked part of the gasket in and was acting just as you described.
5.7YJ is offline
post #7 of 36 Old 04-14-2011, 11:19 AM
EABiker
Answer this one and you will know if it could be a bad sensor; some do nothing until the engine warms up!
EABiker is offline
post #8 of 36 Old 04-14-2011, 12:05 PM
Whimppey
I agree with EABiker. I had the same problem. Once it was warm it would sputter in lower gears. Replaced the upstream (?) O2 sensor, which only sounds intimidating and took longer to get the wranch out than to replace it. No problems since.
Whimppey is offline
post #9 of 36 Old 04-15-2011, 03:06 PM Thread Starter
InEmberClad
Thanks for the tips guys! I will take a look at all these things on Sunday when I get a day off and report back.
post #10 of 36 Old 04-19-2011, 02:21 PM Thread Starter
InEmberClad
Alright, so I checked the fuel pressure and it was good, tightened some other things up, swapped fuel filter and plugs again just for good measure. Now it has a miss around 1200 rpm (idle) and it still hesitates at times. Problem is it will do the sputtering/hesitating thing both hot and cold, and then sometimes it wont do it for days.
I hate just throwing parts at it but you can't pull codes in Jeeps this old, and the TPS hasn't been replaced as long as I've had it. O2 sensor I did replace but over a year ago so it could be all fowled up too...
I did also notice that my plugs are getting fowled up fairly rapidly. Mostly the white kind, not the black crusty kind. Could this be part of the same problem?
post #11 of 36 Old 04-19-2011, 02:34 PM
Drix
What kind of plugs are u using? Also did u check the wires distributor cap and rotor? Clean the rotor and cap see
If that helps. If your wires are old ohm them out anything over 5 ohms is bad. But realistically 2 or higher u might need to replace them.
Sounds like your running hotter spark plugs if they are turning white try a cooler running plug like champion or autolights.
95' YJ 4" lift 33"x12.5r15's D30/8.8 locked with 4:88's
USMC Jeep Club #6
"Why in hell can't the Army do it if the Marines can. They are the same kind of men; why can't they be like Marines."
Gen. John J. "Black Jack" Pershing, USA; 12 February 1918
Drix is offline
post #12 of 36 Old 04-19-2011, 03:02 PM Thread Starter
InEmberClad
I actually am running champs in there right now so we'll see if that helps the fowling problem, but it still has a little miss. I'll take a look a the cap and rotor and wires when I get home today, they're both about a year old but you never know when stuff will just crap out so that could be it.
post #13 of 36 Old 04-19-2011, 03:58 PM
maddoc
Here is a good site on interpreting your spark plugs
http://www.classictruckshop.com/club...park/plugs.htm
maddoc is offline
post #14 of 36 Old 04-19-2011, 08:15 PM
tmontana
I had the same issue and it became worse rapidly. The engine bucked at around 1800 rpm hot and cold when shifting from 1st to 2nd gear, replaced the throttle position sensor for $35 bucks, fixed it instantly.
tmontana is offline
post #15 of 36 Old 04-20-2011, 07:37 AM
91yjrig
I am going through it right now and it was my fuel pump its getting replaced today I did it all plugs wires cap button complete tune up and then I would completely lose power so your pump may be going out cause mine would start off in first fine but Escondido and on I would completely lose power and it would almost die. And just yesterday the fuel pump went completely.
91yjrig is offline
YJ sputters and hesitates thanna1 YJ Wrangler Technical Forum 1 03-18-2010 04:53 PM
YJ Hesitates When Accelerating Genowitz YJ Wrangler Technical Forum 1 02-26-2010 09:39 PM
YJ hesitates&stalls every now & then jathy YJ Wrangler Technical Forum 8 03-20-2009 09:41 AM
03 TJ Hesitates When Hot GilaMtnJeep TJ Wrangler Technical Forum 4 09-16-2008 07:59 PM
4.0L engine Hesitates sometimes 92wrangler YJ Wrangler Technical Forum 2 04-11-2005 10:03 PM
