2.5 runs but misses under load - JeepForum.com
post #1 of 6 Old 05-06-2009, 09:59 AM Thread Starter
95_jeep_yj
I got my first Jeep about a month ago, I have been reading the site since. The 2.5 never has overwhelmed me with power but now it wont hardly pull itself. It idles okay and when you rev it slowly but when it gets to about 4grand it misses and drops doen to about 2,500. When pulling itself it win't rev above 2,000rpm and has a top spedd of about 40. I changed the fuel filter, dist. cap, rotor, and plugs. That didn't change anything. It is running about 30lbs of fuel pressure at idle and 40 revved, I don't see a drop when it starts missing. Any ideas as to what the problem could be?
Thanks in advance for any help, Seth
95_jeep_yj is offline
post #2 of 6 Old 05-06-2009, 10:55 AM
Que89YJ
Miss
Check the FAQ and run diagnostics by cycling the key. Read the faults and post if there are any.
Que89YJ is offline
post #3 of 6 Old 05-06-2009, 11:41 AM Thread Starter
95_jeep_yj
I read the FAQ didn't see anything to help me. I tried cycling the key already with no codes. On a manual tranmission should you press the plunger down to turn the key all the way off when cycling for codes?
post #4 of 6 Old 05-06-2009, 11:54 AM
Que89YJ
Cycle the key from off to ignition on(the cluster turns on) then off again 3 times. The CEL light will blink if you have done it correctly. Here is a good explanation
http://www.allpar.com/fix/80s-codes.html
Que89YJ is offline
post #5 of 6 Old 05-06-2009, 11:59 AM
SECorBust
You need to check the power to the coil. My jeep had a short at the coil and would run intermittently. It definately sounds ignition related. Also everyone always says to check the crank position sensor.
95 Jeep wrangler 2.5 AX-15 conversion.
SECorBust is offline
post #6 of 6 Old 05-07-2009, 09:16 AM Thread Starter
95_jeep_yj
Thanks for the help guys, I finally got it figured out. The catalytic converter was bad, the crap inside was broken loose and had plugged the exhaust. I just drilled a 2" hole in it and pulled everthing out. Not it sounds like one of them damn rice-burners gotta get that hole welded back lol
Engine misses under load - 4.0 L Pumpman YJ Wrangler Technical Forum 2 11-28-2009 08:07 AM
TJ Runs bad under load superboop TJ Wrangler Technical Forum 14 04-05-2009 10:07 PM
4.0 Engine runs rough under load need help snaustin09 YJ Wrangler Technical Forum 4 12-27-2008 09:11 AM
95 YJ 2.5 runs rich, misses at 3k rpm, I have tried a lot ritjobbie YJ Wrangler Technical Forum 16 08-18-2007 03:29 PM
91 YJ Runs fine when cold, misses when warm c21no1 YJ Wrangler Technical Forum 1 04-17-2005 10:50 AM
