2.5 performance? - Page 3 - JeepForum.com
post #31 of 41 Old 05-06-2010, 12:12 AM
moonshinefuel
I know, I have heard all of the terrible stories and evils of alcohol. 3 years later, 287,000 miles original block. And when I am onword towards 400,000 miles, people will warn and try to protect me of it again. . Thank you, please continue.
moonshinefuel is offline
post #32 of 41 Old 05-06-2010, 06:02 AM
Area.3.Fiftyone
Originally Posted by xdgt03 View Post
I'm guessing that we can do no better than gain 15hp (freeing) and 15ftlb torque with exhaust, intake, and fan mods.
A roughly 10% increase in power for those little mods is pretty substantial any day of the week.
I'm not looking to ultimate power out of this little motor, but +15 hp would make a noticeable difference IMO and definitely help on the highway.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #33 of 41 Old 05-06-2010, 07:26 AM
xdgt03
Have you even done this mod along with opening the intake manifold to match? Doesn't sound like it?
Nope. I think I said (maybe it was in another thread) that I did the 4.0L tb swap but did not do the porting of the inlet. The porting of the inlet is the important part here. More air is good, but less velocity is bad. For me, it was the first mod I did and it didn't work at all. I think it was even a little worse. However, since then I have done a few other things including swapping to clean ford 19lb injectors. It is running fantastic right now. Unless there is a strong headwind or I have to go up a hill on the freeway, I can maintain a true 70 to 75 mph (adjusted for tires) pretty easily. These injectors are great IMO. So, putting the 4.0L tb back on might work better now. Porting the inlet would be even better.
I was only attempting to point out as it relates to hp that sometimes in the pursuit of raising hp you can lower tq. This is not good.
Agreed. For other cars you talk about $ per HP/Tq For our 2.5L the cost per HP/Tq is higher than many other cars, but we have a lot less options. So 10% increase for electric fan, exhaust, injectors, etc... cost is pretty good.
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #34 of 41 Old 05-06-2010, 07:31 AM
sloan74
Originally Posted by YJake View Post
Regearing your axles will be your best bet. I've done just about every 2.5L mod tehre is and they do all help when added together, but I plan to regear to 4.88 with 33's down the road. Heck, I may even regear to 4.88s with 31's.
Jake
I am going to regear end of summer. 4.11 now and with these 33" I can barely go past 60 MPH on the interstate....unless I am going downhill of course..LOL
I 100% agree, regearing to 4.88 is the way to go and will help the most.
BTW how much work is involved? Do I just need to purchase the gear/pin? Or are their other parts needed. I just did the rear differential fluids and installed a new seal, so I can get to the gears, etc. But I have not gone any further than that.
sloan74 is offline
post #35 of 41 Old 05-06-2010, 07:40 AM
Area.3.Fiftyone
A lot.
It's not just a matter of swapping in a ring and pinion.
You need master install kits for both axles, new seals, etc. Plus a bit of work to get the contact pattern within spec using a dial indicator and some grease.
It is not a typical remove and replace kind of deal. You really have to know what you are doing for them to last.
post #36 of 41 Old 05-06-2010, 07:58 AM
xdgt03
Here is the thread about porting the head, etc...http://www.jeepforum.com/forum/f12/2...e-look-457885/
He said he dyno'd at 140bhp after increasing the displacement by .2 liters (.060 over), porting the head, header, and exhaust. The stock HP number is 130HP but that is engine hp not bhp. Roughly, the stock bhp number should be around 105bhp. This means his mods actually gained him 35bhpish. He never did post his tq numbers but most certainly they must be higher at least some. Plus, he had not done the injector swap, nor a 4.0l tb swap, and is running with the stock airbox. Hmmm
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #37 of 41 Old 05-06-2010, 10:34 AM
sloan74
Gotcha Stan. I will throw up a request for a DIY maybe come end of summer on re-gearing. Sounds like there will be quite a few steps and some research on my part.
sloan74 is offline
post #38 of 41 Old 05-06-2010, 10:59 AM
samsonitesamson
Ever watch extreme 4x4? I think every other episode is a DIY guide to R&P installs.
When thou walkest through the fire, thou shalt not be burned; neither shall the flame kindle upon thee ~ Isaiah 43:2 ~
Originally Posted by Bnabb View Post
it bolted right up, except one bolt but i didn't need it anyway
samsonitesamson is offline
post #39 of 41 Old 05-06-2010, 11:48 AM
SDGBASSE
Here's a link to some dyno results of a 4.0L TB, and how sure are you guys about that 14.7:1, because I've been taught that on newer vehicles the factory ECU program leans the ratio a bit to lower the fuel consumption?
Originally Posted by ZeroGravity View Post
I didn't click the link because it says "power probe" in the url.
SDGBASSE is offline
post #40 of 41 Old 05-06-2010, 01:46 PM
xdgt03
14.7 to 1 is considered the stoichiometric air/fuel mixture. Anything more than that is considered lean and any thing less is considered rich. Lean can be very dangerous because it causes the engine to run hotter. Way hotter. Hotter such that internal parts can warp and melt. Gas is not just used for the "bang" but also for cooling the combustion chamber. Oxygenated fuels can lower the a/f ratio to somewhere around 14.1 to 1 but as you see it is only very marginal. On more modern engines with special alloys and coatings I can see that the ratio could be leaned out a tad.
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #41 of 41 Old 05-06-2010, 01:58 PM
xdgt03
Here's a link to some dyno results of a 4.0L TB,...
His baseline was 125.3hp Typically, chassis or axle dyno's produce readouts in BHP not HP. Now I don't know if this engine was on an engine stand, compensated for driveline loss and rated at bhp (displayed as HP), or if he did other mods which raised his bhp number but the 90's YJ's came with 130 engine HP. Some clarity on this would help.
If he had done other mods and the readout was in bhp I can see that the 4.0l tb swap could help since it is compounding the benefit of the other mods. 7bhp seems like a lot but not out of the question.
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
Hawk Performance HPS High Performance Street Disc Brake Pads? NW Jeep TJ Wrangler Technical Forum 54 11-02-2011 09:54 PM
More air In > More air Out= Performance ? 05jeepkj TJ Wrangler Technical Forum 38 02-23-2009 11:44 AM
2.5 performance Nates93yj YJ Wrangler Technical Forum 24 02-16-2009 05:20 PM
performance and not performance shocks MODUS TJ Wrangler Technical Forum 4 12-02-2007 10:53 AM
258 performance Joe jeep YJ Wrangler Technical Forum 8 01-11-2004 10:14 AM
