2.5" lift...parts needed? - JeepForum.com
post #1 of 2 Old 07-25-2006, 01:22 PM Thread Starter
BillR
BillR's Avatar
This will be my first lift on a YJ, so sorry about the newbie question...
I have the springs (w/shims) and shocks. What else is needed? Drop pitman arm? T-case drop? Brake lines needed?
What size are the u-bolts so I can get new ones?
TIA!
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #2 of 2 Old 07-31-2006, 11:59 PM
smokeybear
Depending on the kit you get, it might have all, some, or none of the parts you need. You will need a transfer case drop kit and new U-bolts. Order a set from Quadratech or any other 4x4 parts place - they know the right size. Shouldn't need a pitman arm. Check the suspension at full droop without the shocks to see if any brake lines are stretched. Turn the front wheels side to side to check the brake lines. Might or might not have to fabricate brake line relocation brackets.
02 TJ Sahara 4.0 5 spd, 3.73, Dana 44 rear, 2.5" lift w/ Bilstein shocks, 33x12.50
smokeybear is offline
Pics of TJ with 2.5" RC Lift with 32" Tires? Please help! (Any other parts needed?) dirttrackfans Jeep Picture Requests 22 06-07-2010 08:58 PM
Parts needed to lift a 99 wrangler TJ steve99tj TJ Wrangler Technical Forum 6 01-14-2009 06:11 PM
Additional Parts Needed for RE 4.5" SF on 2006 Rubicon. india TJ Wrangler Technical Forum 17 08-29-2008 11:58 PM
suggestions... (parts needed with FT 3" economy kit) cotman1 TJ Wrangler Technical Forum 2 02-27-2008 09:51 PM
Body Lift Parts needed Bluevee33 YJ Wrangler Technical Forum 0 11-06-2007 07:39 PM
