2.5 L water pump replacement - JeepForum.com
post #1 of 14 Old 06-03-2010, 03:38 PM Thread Starter
ZonaWrangler
Hi,
I'm currently replacing my water pump. I did this once before with someone who knew what they were doing and it seemed pretty easy. Anyway, I remember we removed the fan clutch. I see that it has 4 bolts on it, but they seem to be lock bolts, and when I try and turn them, the tension of the belt is not enough to get them off. HELP, how do I remove my fan clutch?
TIA
95 Wrangler Rio Grande. Herculined, AEM Brute Force, Helix TBS. No lift, Viper alarm, Primax rims and 30 x 9.5 Dunlop ATs. Gabriel HD shocks. My DD. Mostly ..... mostly.
ZonaWrangler is offline
post #2 of 14 Old 06-03-2010, 03:50 PM
Rhino70
First remove the belt. Then hold the fan blade with one hand and turn the bolts with the other!
Rhino70 is offline
post #3 of 14 Old 06-03-2010, 03:58 PM Thread Starter
ZonaWrangler
How do I get the belt off?
post #4 of 14 Old 06-03-2010, 04:17 PM
Rhino70
By the power steering pump.
do a search on power steering pump removal...
Rhino70 is offline
post #5 of 14 Old 06-03-2010, 04:36 PM Thread Starter
ZonaWrangler
I don't have power steering. Sorry, I'm a mechanical moron.
post #6 of 14 Old 06-03-2010, 04:46 PM Thread Starter
ZonaWrangler
Ok, I found a few things that explain it. Thanks.
post #7 of 14 Old 06-03-2010, 05:00 PM
Rhino70
I also drive a 95 rio grande and you should have power steering...that water pump is super easy to do, just take your time and be sure to seal it good with the rtv.
Rhino70 is offline
post #8 of 14 Old 06-03-2010, 06:16 PM
MoparFreak69
Depends on what year rig you are working on. My 90 had 2 v belts (before I yanked that sorry excuse for an engine out of its hidey hole) and the alternator belt was in front of the power steering belt. To remove the nuts I just use a screw driver to pry against a nut on the other side and the fan shaft and turn the wrench with the other hand. Go around and do all 4 then just take them off the rest of the way easily. The fan will probably be pretty snug/rusty on the water pump shaft so you might have to smack it around a bit with your palms (NOT hammer). I like to wait til I get the fan off before I remove the belts just for the extra help the tension gives in removing the fan nuts. After the belts are off then the pulley will come off and the rest should be self explanitory.
If you are working on a later one then the only real different is the belt is longer and wraps around everything.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #9 of 14 Old 06-04-2010, 01:04 AM Thread Starter
ZonaWrangler
It's a 95 with AC. I have another car to drive, so it's no rush. I did it before with a friend in an afternoon, so I know it's not that bad. But I remember we removed the belt and I think the entire fan blade assembly came off too. Not sure I am looking at the right 4 bolts, they are on the back of the fan clutch itself?
post #10 of 14 Old 06-04-2010, 01:06 AM Thread Starter
ZonaWrangler
It does NOT have power steering. However, it's the same setup. Box and a pump ... it's got power steering. The pulley is there for it.
post #11 of 14 Old 06-04-2010, 01:14 AM
moonshinefuel
Good answer!
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #12 of 14 Old 06-04-2010, 02:53 AM Thread Starter
ZonaWrangler
I realize a water pump should be an afternoon job .... but I'm an idiot. That throws a whole new dynamic into the situation.
post #13 of 14 Old 06-04-2010, 08:00 AM
EABiker
You can also push down on the belt, (hard), with one hand to hold the fan from spinning. Another tip: clean the gasket surface on the engine very carefully so not to leave any old gasket material if you want to avoid leakage! And.... when you install the new gasket, use a very thin bead of RTV, (blue),down the center of both sides of the gasket and around any bolt holes or water passages. Do not use too much RTV as the excess will squish out and clog the heater core. Finally, when you refill with coolant, make sure you purge the air from the system.
Lastly, spend the $$$ for a new pump if you can, the re-builds can be a crap shoot!
EABiker is online now
post #14 of 14 Old 06-04-2010, 12:17 PM
WhiteYJLA
Message me I'll send you the instructions from the manual.
WhiteYJLA is offline
Water pump replacement jbrem TJ Wrangler Technical Forum 15 06-18-2010 08:23 AM
Need Help with Water Pump Replacement younts22 TJ Wrangler Technical Forum 4 08-03-2009 07:52 AM
Water Pump Replacement Speedracr13 TJ Wrangler Technical Forum 5 02-12-2007 04:15 PM
Water pump replacement kanai YJ Wrangler Technical Forum 12 01-10-2007 03:56 PM
Water Pump Replacement dbag97 TJ Wrangler Technical Forum 5 10-24-2006 01:42 PM
