2.5 L Throttle body upgrade - JeepForum.com
post #1 of 4 Old 05-30-2013, 10:42 PM Thread Starter
djhrn1
OK have a question, Was complaining the other day to one of my friends who is a mechanic about the lack of power in my 1990 yj with the 2.5 L. He suggested changing to a 4.0 L throttle body and this should help some. I'm wondering what's compatible. Does he mean the whole throttle body or just a spacer and what years should I be looking to swap from. Is there any other way with some simple bolt-ons to achieve any better performance. Help a newbie out here I always appreciate some good advice. Working on a budget. Thanks Dave
djhrn1 is offline
post #2 of 4 Old 05-30-2013, 10:52 PM
Xpress
Since your YJ is a 1990 it should be Throttle Body Injection (TBI) from the factory. This is a proprietary unit that cannot be swapped or replaced. You basically have one big injector that is mounted inside of the throttle body before the butterfly valve, not 4 separate injectors like 1991-1995 2.5L YJ's.
All about that unibody life.
Xpress is offline
post #3 of 4 Old 05-31-2013, 07:14 AM
dcocch
Xpress is correct...I have the same issue with my 89.
dcocch is offline
post #4 of 4 Old 06-01-2013, 12:55 AM Thread Starter
djhrn1
Is there anything you can do to upgrade street performance that's a cheap fix or junk yard swap
djhrn1 is offline
