2.5 Hard Start.. Help a Girl out.. - JeepForum.com
post #1 of 6 Old 03-04-2014, 10:37 AM Thread Starter
karenmascaro
Have a 1992 Yj with a 2.5
Crank Crank Crank takes forever to start 99.9 percent of the time
Cleaned up Throttle body, new intake, seems like a fuel problem?
When she starts runs great but then does not want to start again just crank but not turnover.
Also this came off and I cant find where it goes, what is it for??
Thanks all.
karenmascaro is offline
post #2 of 6 Old 03-04-2014, 10:58 AM
hardluk
1987 YJ Wrangler
Those are vacuum hoses that go to your EGR. The end with the two small elbows connects to your air intake on top of your motor. Can't remember about the other ends off hand. Just search for vacuum or EGR hose routing. Might fix your starting problem.
hardluk is offline
post #3 of 6 Old 03-04-2014, 11:00 AM
Mark05059
I would sooner say your having capacitor issues. When you first turn the key wait until your check engine light comes on and goes off.. then crank it over.. should start right up.
I would find where the hoses go for the egr though.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 6 Old 03-04-2014, 11:48 AM
Que89YJ
No egr on hers.
Que89YJ is offline
post #5 of 6 Old 03-04-2014, 04:34 PM
lar308
Try cycling the key 3-4 times,waiting 10 seconds between, then try to start. Most cold start issues are fuel related, by cycling the key it may help narrow down a fuel pump issue. please fill out your jeep profile, Ron
"Snowball" 1990 YJ, 4.2, Weber, HEI, 3.5" springs, .5" boom shackles, dana 44's, 5.13's, Detroit locker's, 4340 axle shafts, 1 ton trod ends, Tom Woods SYE & rear shaft, 35" MTR's on V5 cragars, M8274
lar308 is offline
post #6 of 6 Old 03-09-2014, 07:43 AM Thread Starter
karenmascaro
I put a new crown CPS in and it took care of the problem starts right up, Thanks for all the input, wonderful forum
