2.5+AX15 swap complete! - Page 3 - JeepForum.com
post #31 of 49 Old 11-11-2011, 07:41 PM Thread Starter
czjeeper
I rocked it with no problems. My 2.5 was getting long in the tooth, so my AX15 is behind the 5.2 I'm swapping in.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #32 of 49 Old 11-25-2011, 09:50 AM
MrMoparNY
Great write up, now that I own a sizeable lot, with a huge old storage building, I can start pickin up cheap donor vehicles and have plenty of room to store them...I've had to send some good stuff to the the scrap yard in the past, that I wish I had back...
MrMoparNY is offline
post #33 of 49 Old 11-28-2011, 03:39 PM
YJake
After what seems like a Coon's age I have finally got my rebuilt AX15 behind my 2.5L with a rebuilt np231/SYE and CV shafts front and rear. However, I have not yet driven the Jeep except to move it forwards and backwards in my driveway.
Observations.
-The clutch has lost resistance but seems to be working just fine as far as engagement goes... does it need bled? (I have a prebled external slave unit)
-The AX5/NP231 T-case shifter does not work (obviously) is there a way to modify it or am I stuck looking for a 4.0/ax15 T-case shifter assembly? (I want my 4wd back!)
And that's all for now... I need to bleed my brakes and take it for a spin around the block to see how it shifts, so till then gents.
-Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #34 of 49 Old 01-19-2012, 09:47 AM
smallJEEP
Is there a reason i can not use my 94 4 cyl bell housing with external slave.. and bolt the ax-15 to it. i was told they were the same pattern. if i need a Dakota bell housing can i not use the trans from the Dakota? what trans did the Dakota come with?
smallJEEP is offline
post #35 of 49 Old 07-22-2013, 02:43 PM
Jdh95jeep
I have 95 yj and just completed the modify everything swap. Do I have to modify my skid plate? And also I did not change the pilot bearing. Will this be a problem? Also my slave was already external and bolted rite up. That have to be modified? This is driving me f#$&@! Crazy! ! Spent almost $1600 so far.
Jdh95jeep is offline
post #36 of 49 Old 07-22-2013, 04:23 PM Thread Starter
czjeeper
If your skid plate has slotted holes already (like mine did) you are good to go.
I would have changed that pilot bearing. I don't want to be a bummer, but most likely you will have issues. Did the AX15 snout fit the existing pilot?
Did you buy everything new? Mine wasn't that pricey...
US Army combat vet
czjeeper is offline
post #37 of 49 Old 07-22-2013, 07:44 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
$1600?? I spent maybe $500 on the swap, including the transmission and transfer case.
Pilot bearing should have been changed. Since you already had it apart, a few extra dollars for a new pilot bearing/bushing would save you a ton of hassle if it fails early.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #38 of 49 Old 07-22-2013, 08:49 PM
Jdh95jeep
ax5-15 swap (95yj)
Yeh mine has slotted holes. Whew. Yeh it went rite in. What problem would I run into and if I do change the bearing is it something that is easy to change and can I get it from autozone or Napa?
Yeh close to it! Dont see how you got away with $500... wow lucky!
Ax15 completely rebuilt $800
Bell house $120
Drive shaft mods $350
Clutch disk from auto zone $100
Had to buy complete kit to get the disk
Drove 2 hrs to get ax15 bracket
$50 not including gas
Fluid... $
I was told from corey transmision here in Charlotte to use 10w30
He rebuilt my ax5 and I ran 10w30 in it for a few months. Ran great!
Sold the rebuilt ax5 for $800 (what I paid to have it rebuilt.
Still need shifter... $ so total will be close to $1600
post #39 of 49 Old 07-24-2013, 08:49 PM
Jdh95jeep
she works!
Old pilot bearing works fine. Slave works fine!
post #40 of 49 Old 09-04-2014, 01:06 PM
Ggg
Sorry if this is redundant but the NAPA part number RCF584 for the friction disc is no longer a good number. They can only get the clutch as a kit.
I have yet to find a part number for the friction disc only.
The Novak part number of 716167 is not a Novak number either, it is a good Advanced Adapters pilot bushing part number. So call AA to get that part.
Ggg is offline
post #41 of 49 Old 11-24-2014, 11:50 AM
jdmda9noke
I know this is a old thread, but my trans took a crap on me last week and I have a nv3550 in my garage awaiting my om617 swap,
My question is can I use my nv3550 clutch fork or do I need the Dakota one?
Any other new tips would be greatly appreciated
jdmda9noke is offline
post #42 of 49 Old 12-13-2014, 01:52 PM
Richard_
I have an ax15 from what I believe is from an 92 yj , is there any parts I can use from my ax5 ? Or do I need every thing ? I know I need a bell housing and clutch , what about clutch fork and slave ? Can I use them from the ax5 ?
Richard_ is offline
post #43 of 49 Old 12-18-2014, 07:20 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Yes. You can use the clutch fork from the AX-5 as well as the slave. Not a problem. You will need the AX-15 external slave style bearing retainer though, since your AX-15 is from a '92 with an internal slave.
-Matt
White '94 YJ Sport
UltimatE is offline
post #44 of 49 Old 01-04-2015, 07:17 PM
Richard_
I bought an external slave bearing retainer , what about the seal ? Should I replace it ?
Richard_ is offline
post #45 of 49 Old 01-04-2015, 07:57 PM
LoneYJranger
Since you are already there I'll be a good idea to put a new seal in
"Who put this thing together, Me"
"Who do I trust, Me"
With the help of jeepforum.com of course
LoneYJranger is offline
99 Tj Ax5? Ax15? To 92 Yj Ax5 Swap??? Help Please whatmud78 YJ Wrangler Technical Forum 0 09-04-2009 11:44 AM
2.5L AX15 swap czjeeper YJ Wrangler Technical Forum 2 12-26-2008 06:38 PM
AX5 to AX15 swap gatorkiller YJ Wrangler Technical Forum 5 05-20-2008 12:34 AM
305 Swap into my YJ with ax15 jvidmar YJ Wrangler Technical Forum 2 08-28-2007 10:05 PM
ax15 swap 5.0YJ YJ Wrangler Technical Forum 5 11-30-2006 02:27 PM
