2.5+AX15 swap complete! - Page 2 - JeepForum.com
post #16 of 50 Old 03-08-2011, 06:42 AM
sgrind1
i plan on getting started ordering the parts to do this swap,but just a quick question and maybe a few more on the way as far as the 96 dodge dakota bell housing is there a certain motor size i should be looking for and when i find one is there anything i should be sure to keep on it. and just so i get it i can us any yj or tj ax15 94 and up.
sgrind1 is offline
post #17 of 50 Old 03-08-2011, 06:56 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Yes, you need to get a 96-98 Dodge Dakota 2.5L / 5speed bellhousing. I'm pretty sure the AX-15s 94+ are bolt in as well.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #18 of 50 Old 03-08-2011, 07:27 AM
sgrind1
thanks
sgrind1 is offline
post #19 of 50 Old 03-08-2011, 11:14 AM Thread Starter
czjeeper
In the next few months, I'll be pulling the 2.5 and installing the SMPI 5.2 Magnum.
I'll let you know, if you are interested.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #20 of 50 Old 03-08-2011, 12:34 PM
imstillatwork
I want to do this one day, but with the 4.0 still attached.
imstillatwork is offline
post #21 of 50 Old 03-09-2011, 05:51 AM
sgrind1
ok thanks
sgrind1 is offline
post #22 of 50 Old 03-14-2011, 06:20 PM
ROCKO
1998 YJ Wrangler
I just did the same swap to my 98 jeep Wrangler 2.5, but now I have very little resistance on my clutch pedal and The Trany moves into gears witout pressing the clutch down.. I already tried Bleeding the Slave cylinder and took it out again to manually pump it.. And the trany still doesnt work. Any suggestions on what It might be? a New Slave Cylinder or master cylinder?
ROCKO is offline
post #23 of 50 Old 03-14-2011, 07:03 PM
moonshinefuel
So it's stuck now? The clutch is not releasing fully right now? Does the release happen on the pressure plate after you take out the slave cylinder? If yes, then just replace with a complete pre-bled system if you can spend for that as long as you determined that the pressure plate is releasing properly after you removed the slave cylinder, then obviously it is in the hydraulics somewhere. If not, then it seems like a problem within the pressure plate area somewhere. Sometimes it's the opposite problem of what you are having, with this conversion, to where the slave pin is not long enough. Many people sleeve it adding one inch, or up to one and one quarter inches tops. But this seems to be not a problem in your case.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #24 of 50 Old 03-15-2011, 08:15 PM
ROCKO
1998 YJ Wrangler
Thanks, yea, I rounded it down to adjusting the clutch peddal or something within the bellhousing.. I wanted to ask because I see pictures on here about the fork spring being on the outside of fork ball and over the ballsocket behing the fork ball itself, How is this spring supposed to be installed correctly? I replaced the Hydr Cyl with new one, re Bleed it and it has potential Resistance but the trany still enters all gears without the pressing down on the clutch. So I am stuck right there. Turns on throwout bearing sounds loose and trany wont engage into any GEAR! Grrrr!! what did you say about the clutch itself? what would be wrong, I installed it just as it is suppose to be facing proper directions and lbs.... thanks again for helping!
ROCKO is offline
post #25 of 50 Old 03-15-2011, 08:49 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I'm running a stock length clutch slave pin, works fine.
I would start by removing the slave cylinder, tying it up, and attempting to drive it. If you can start the jeep, and it won't go into gear without the clutch, then the problem is the hydraulics not releasing.
If it still acts the same, your problem is mechanical and inside the bellhousing.
-Matt
White '94 YJ Sport
UltimatE is offline
post #26 of 50 Old 03-16-2011, 09:58 AM
ROCKO
1998 YJ Wrangler
well the New Hyd Cyl works good now after bleeding her, but the problem remains the same is that the shifter goes into gears with or without using the clutch pedal. All Gears engage in and out. Im going to remove the Hyd Cyl and use a long screw driver on the Bearing Fork to see if engages that way or if will stop the problem. I feel that MoonshineFuel hit the jackpot with the short stock Hyd Cyl pin. Thanks Guys! Ill let you know what the problem was if I find it.
ROCKO is offline
post #27 of 50 Old 03-16-2011, 12:26 PM
ROCKO
1998 YJ Wrangler
Droped the trany again.. bc I have no pressure whats so ever when moving the shift stick into all gears with or without pressing on clutch pedal. I don't understand what I am doing wrong. I followed instructions to the T , but I'm thinking the Clutch itself isn't pushing out when I tighten it up against the flywheel. That's why the bearing has nothing to push down against. hmmm?
ROCKO is offline
post #28 of 50 Old 03-16-2011, 12:34 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Can you post up pictures of what you're working with? The stock length slave rod works without issue, I've been driving my conversion for a year and a half with it. There is at least one other member that I know of for sure using it as well.
-Matt
White '94 YJ Sport
UltimatE is offline
post #29 of 50 Old 11-11-2011, 10:09 AM
aparke4
any feedback since install? I am wanted to keep my 4 cyl TJ motor but beef up the tranny since my jeep is looking like it is going to be used off road more and for hauling a trailer (I have the AX-5)... i have a friend who is a transmission tech and would be assisting in the install...
Thanks!
aparke4 is offline
post #30 of 50 Old 11-11-2011, 10:42 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
What kind of feedback are you looking for? I've just passed 2 years with the swap and it runs great.
-Matt
White '94 YJ Sport
UltimatE is offline
99 Tj Ax5? Ax15? To 92 Yj Ax5 Swap??? Help Please whatmud78 YJ Wrangler Technical Forum 0 09-04-2009 11:44 AM
2.5L AX15 swap czjeeper YJ Wrangler Technical Forum 2 12-26-2008 06:38 PM
AX5 to AX15 swap gatorkiller YJ Wrangler Technical Forum 5 05-20-2008 12:34 AM
305 Swap into my YJ with ax15 jvidmar YJ Wrangler Technical Forum 2 08-28-2007 10:05 PM
ax15 swap 5.0YJ YJ Wrangler Technical Forum 5 11-30-2006 02:27 PM
