2.5 auto starter removal - JeepForum.com
post #1 of 6 Old 02-24-2010, 06:26 AM Thread Starter
brzehentmaier
brzehentmaier's Avatar
Starter went out this morning. I unbolted it and disconnected it but it won't come out. What do I have to do to get it out??? I t seems that the oil pan is in the way. Starters used to be easy as pie, take the two bolts out and it should drop out. Is my sliding gear stuck forward or am I just a little stupid this morning.
Thanks, Bernie
1995 Rio Grande
31 x 10.5 x 15 Tires
1.5 Body Lift - Skyjacker Hydros
2.5 - Auto - Crager "D" Slots
A Work In Progress
2004 Liberty Columbia Pkg.
A new begining
brzehentmaier is offline
post #2 of 6 Old 02-24-2010, 07:38 AM
Brown Dog
Vendor
Brown Dog's Avatar
I've had that problem i the past. I believe I used a rubber mallet to help remove it. Since you are going to replace it, you might use a more substantial hammer (BFH).
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #3 of 6 Old 02-24-2010, 07:56 AM
Djsthe1
Yea mine just fell off.. make sure you dont lose your shim..
Djsthe1 is offline
post #4 of 6 Old 02-24-2010, 08:05 AM
Brown Dog
Vendor
Brown Dog's Avatar
OMG I forgot to mention the shim....good call. Don't lose that sucker!!!
Brown Dog Offroad
91YJ 2.5
2" BL
4.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
post #5 of 6 Old 02-24-2010, 04:42 PM Thread Starter
brzehentmaier
Hey guys thanks for your responses. I beat that starter out with a Big A** hammer and cro-bar. I fixed it and ran to work about 4 hrs. late. It turns out the hammer worked good. Seems that the outer casting of the starter in front where the gear slides was made too big. It was hung up there and scraped away the oversized casting. What a sledge and a small cro-bar can do. Turns out there is 2 different starters for a 2.5 auto in '94 . It depends on when your jeep was built. There is a pre-may "94 and an after may '94. The pre-may is shorter and has a different front nose-cone( not as long), Of course I had to find that out the hard way with 2 trips to the parts store. All in all a twenty miniute job turned into a couple hours but it's done and I'm rolling again.This is when I really mis my old stick. Thanks again for your responses.
Bernie
1995 Rio Grande
A Work In Progress
A new begining
post #6 of 6 Old 02-24-2010, 04:44 PM Thread Starter
brzehentmaier
I didn't forget it but put it in crooked the first time and had a nice ticking from it rubbing on the flywheel.
Bernie
1995 Rio Grande
A Work In Progress
A new begining
Removal of Oil Pan from 2000 TJ 4.0L auto fleck TJ Wrangler Technical Forum 4 08-11-2009 10:00 AM
2.5 Starter Removal fataltherabbit YJ Wrangler Technical Forum 10 09-23-2008 12:36 PM
4.0L starter part # - auto vs manual Giviner TJ Wrangler Technical Forum 2 06-26-2007 02:34 PM
Auto (904) Transmission Removal Raxmar TJ Wrangler Technical Forum 1 04-13-2006 10:39 PM
starter motor removal,. please help samizx7 YJ Wrangler Technical Forum 2 01-27-2006 03:50 PM
