2.5 to 4.0 throttle body swap. Help!!! - Page 2 - JeepForum.com
post #16 of 18 Old 02-28-2013, 09:49 PM
jonothehut
Originally Posted by TCrook View Post
I have a 94 4 banger that I am trying to get a little more juice out of. I swapped to a 4.0 throttle body that I got from a junkyard yesterday. Everything hooked up fine. Crank her up and the engine goes wide open. I shut it off tried again, same thing. Any ideas on what I did wrong? Need some help here.
Thanks,
Tom
I have the exact same issue on my YJ. Only difference is I did swap both 2.5 sensors onto the 4.0 TB before installing the 4.0.
I checked they electrical connections. Everything looks in great condition. I even cleaned the sensors and 4.0 throttle body before install.
I saw on another thread that resetting the ECU might fix the issue? Thoughts on this?
Any ideas on what could be wrong?
jonothehut is offline
post #17 of 18 Old 03-17-2013, 06:51 AM
jonothehut
Figured it out! Turns out I missed the IAC housing. Swapped that and it worked like a charm.
post #18 of 18 Old 04-11-2013, 09:39 AM
jeepstillhaslif
Just curious but is the power a noticeable difference. What exactly does switching to a 4.0 tb do for the 2.5. On another post I read you would have to reset the ecm. Is this true, or is it a straight up swap parts out and put back together kind of project.
jeepstillhaslif is offline
