2.5 to 4.0 throttle body swap. Help!!! - JeepForum.com
post #1 of 18 Old 03-15-2012, 10:29 AM Thread Starter
TCrook
I have a 94 4 banger that I am trying to get a little more juice out of. I swapped to a 4.0 throttle body that I got from a junkyard yesterday. Everything hooked up fine. Crank her up and the engine goes wide open. I shut it off tried again, same thing. Any ideas on what I did wrong? Need some help here.
Thanks,
Tom
TCrook is offline
post #2 of 18 Old 03-15-2012, 10:46 AM
OKwranglerYJ
Did you use the sensors from your 2.5 tb or the one for the 4.0. And it sounds like the throttle position sensor.
OKwranglerYJ is offline
post #3 of 18 Old 03-15-2012, 10:48 AM
idskot
I'd say this. This or the idle air control? Those two are the only sensors in the TB.
idskot is offline
post #4 of 18 Old 03-15-2012, 03:25 PM Thread Starter
TCrook
That was it. Swapped the sensors. Runs like a scalded turtle now. Thanks for the replies.
TCrook is offline
post #5 of 18 Old 03-15-2012, 04:03 PM
benmar2000
It will give them squirrels more air to breath.. Makes them run faster in their cages..
benmar2000 is offline
post #6 of 18 Old 03-15-2012, 04:13 PM
Xpress
Well that's step one. Step two would be to open up that intake and exhaust. Let it really breathe..
All about that unibody life.
Xpress is offline
post #7 of 18 Old 03-16-2012, 10:26 PM
jaredmausteller
I have a 92 yj w a 2.5 in it. I was looking to do the 4.0 tb xchange. My question is what year tb should I be looking for, and is it a direct bolt on?
And do I use the stock 2.5 iac and tps or do I use the 4.0 sensors??
Thanks in advance.......
jaredmausteller is offline
post #8 of 18 Old 03-16-2012, 10:46 PM
benmar2000
I think any TB from a 91 or 92 4.0L (Can't remember what year they switch to the 4.0L) forward will work.. I have a 95YJ but my TB came off a 94 Cherokee.. But you want to make sure it has 4 bolt holes that mount it to the intake.. At least it was on mine.. Also, you want to move over the IAC and Throttle sensor.. You will need a size T20 Tamper Resistant Torx bit to get the IAC sensor off.. It isn't a hard swap.. It will take maybe 10 minutes to do the swap..
post #9 of 18 Old 03-16-2012, 11:25 PM
jaredmausteller
So use the 2.5 sensors on the 4.0 tb?
post #10 of 18 Old 03-17-2012, 05:08 AM
benmar2000
Correct.. On the 4.0L TB, remove the sensors and then take the sensors on the 2.5L TB and put them on the 4.0L TB.. Then bolt the 4.0L TB on and hook up the sensors and throttle cable.. Your done.. As added insurance, I would get a new TB gasket.. I could have reused mine, but decided why take the chance.. It's only $1.99 from Advanced Auto..
post #11 of 18 Old 03-17-2012, 05:14 AM
wendell
1987 YJ Wrangler
You need to use a 4.0 tb from a 91-95 yj and change to the 2.5 sensors.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #12 of 18 Old 03-17-2012, 05:30 AM
benmar2000
A TB from a 4.0L XJ will work also..
post #13 of 18 Old 03-17-2012, 08:02 AM
Xpress
Yup, I believe the XJ's and YJ's got essentially the same powerplants for FI, seeing as how a lot of components are interchangeable (FI, TB's, manifolds, etc).
I could be wrong
Xpress is offline
post #14 of 18 Old 03-17-2012, 08:50 AM
hesserdude07
Jp (i think it was) did a nice write up on this, this month or last month... gave good years to get the TB from and other swaps to do.
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #15 of 18 Old 03-17-2012, 08:53 AM
jaredmausteller
Thanks for the info. I'm looking to put power steering in it so any extra power I can get will help tons....
