2.5 to 4.0 swap - JeepForum.com
post #1 of 4 Old 06-20-2010, 07:34 PM Thread Starter
codeman398
2.5 to 4.0 swap
so i got a 2wd comanche witha 4.0 in it. and i a wrangler with 2.5 in it. i want to swap them. what years of cherokee could i get the t case from. any advise? what will i need to buy besides the t case? this is my first motor swap need a little help. Thanks a ton
codeman398 is offline
post #2 of 4 Old 06-20-2010, 08:24 PM
moonshinefuel
A 2 wheel drive transmission won't work. You will need a transmission too.
moonshinefuel is offline
post #3 of 4 Old 06-20-2010, 09:09 PM
moonshinefuel
So yea, the good thing is, there are many different transmissions you can put behind that 4.0, and a lot of ways to go about this. This will no doubt be a good learning experience, and by noting what you have already purchased, you are jumping right in head first. Should be a fun project. Keep posted here as you go along if you can. Will make for an interesting thread to follow, and keep tabs with.
post #4 of 4 Old 06-22-2010, 12:56 PM Thread Starter
codeman398
so i can swap everything over clean if i get a t case and tranny? and i know i can pull these out of a cherokee. does it matter what years and all that?
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 05:11 AM
body swap VS motor swap questions baltimorebiker YJ Wrangler Technical Forum 9 03-29-2010 10:49 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 04:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 04:28 PM
