1st year anniversary (ome springs and shocks) - JeepForum.com
post #1 of 4 Old 08-17-2011, 02:09 PM Thread Starter
gunshw301
Paper is supposedly what your supposed to give for your 1st year anniversary. Well I got that in spades!
In amongst all the paper I found a set of 2.5 inch ome springs, shocks, and steering stabilizer.....shes so good to me!
Some comparison shots of the new springs vs the old one I managed to get loose today.
One last poser shot of the stock flex.
I had the day off so I thought I would get it installed. I knew I would be okay on the shackle end since I had them apart less than 2 months ago. I got stuck on the main spring mount and bushings. I tried everything to get them off but I just couldn't get the bolt to push through. Figured they were rusted up (it was) so I had to resort to cutting.
That pretty much stopped my progress since I was planning on reusing the main spring bolts. Now I am ordering a set of grease-able bolts and new bushings.
http://www.quadratec.com/products/16090_701.htm
http://www.quadratec.com/products/16311_5505.htm
Since I was dead in the water with the springs I decided to move on to the steering stabilizer. Once again rust got the better of me and now I am trying to figure out how to get the old damper off the drag link. Tried a puller, heat, air, lube...nothings working. Looking at buying a better puller, I think that's my main problem.
Well that's about it for the day. I will update as progress occurs, any suggestions on the damper will be appreciated.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #2 of 4 Old 08-17-2011, 03:03 PM
USMC3531
Yeah, sounds familiar. I just finished with my lift. Same problem with the factory spring eye bolts....had to resort to an 8 inch grinder with cut off wheel, being careful not to cut into the spring bracket. I went through a whole pile of recipro saw blades before I went to the grinder.
As for the steering stabilizer, I think I used my air hammer with a ball joint fork. It didn't want to come easy though.
USMC3531 is offline
post #3 of 4 Old 08-17-2011, 03:46 PM
TheNewbie
Congrats on your first year. And on finding a woman who can appreciate your love for the Jeep!
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #4 of 4 Old 08-17-2011, 04:22 PM Thread Starter
gunshw301
Yeah, she knows my love for the jeep. Unfortunately she isn't fully on board with the idea. The only way I got this was I gave her my user name and password to my wish list at quadratec! She is great though, no complaints.... that first year flew by.
My TJ has 5 year old Pro-Comp lift--what are my options to replace shocks OregonMTB TJ Wrangler Technical Forum 10 10-17-2010 05:53 AM
1 Year Anniversary Rubicon JK richor Wrangler General Discussion 7 01-22-2010 12:53 PM
What year did they start using coil springs? FLYKELLEY YJ Wrangler Technical Forum 10 09-29-2009 01:55 PM
Are 17 year old leaf springs strong enough? JohnnyChimpo YJ Wrangler Technical Forum 13 05-18-2008 10:26 PM
9 year old Stock springs with 100k miles = sag? Dekemonger TJ Wrangler Technical Forum 6 10-22-2006 09:22 AM
