1pc front axle shaft vs Posi-Lock - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1pc front axle shaft vs Posi-Lock
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 06-29-2012, 10:50 PM   #16
sardog211
No I did not replace a seal, where exactly does this seal go In at? I guess I missed something? I don't recall a seal when I took the old one out. Is there any pics of where this thing goes?
sardog211 is offline   Reply With Quote
Unread 06-30-2012, 06:44 AM   #17
fbv193
The seal goes in the axle tube next to the differential. With the CAD, the axle is sealed outboard of the CAD, to have the CAD lubricated. When switching to a one piece shaft, a seal needs to be placed next to the diff in the same manner as the drivers side shaft. The seal that worked for the CAD system is too large in diameter to seal with a one piece shaft. It will work as a "dam" for a while on level ground, but will soon be leaking gear oil out your tube.
Lots of threads on here with instructions, but the diff carrier will need to be pulled in order to install the seal.
I use a Seals-it EAS3-05 when I put a one piece shaft in. A bit pricier than the 11800, but easier to install.
fbv193 is offline   Reply With Quote
Unread 06-30-2012, 07:18 AM   #18
notmyj
Another Jeep Guy
notmyj's Avatar
Originally Posted by fbv193 View Post
Here is a pic of the stripped splines on my second intermediate shaft, the first one looked exactly the same. I blamed the first ruined shaft on the vaccum system, but the second stripped the splines the same way with the cast iron shift fork and the posi-lock. Was pulling a load of firewood up a steep grade running over some stumps and the splines let go with a BANG. I do wonder if the TrueTrac allows the intermedate shaft to go further inboard, lessening the engagement of the shift collar.
Now running a one piece shaft and would not consider anything else.
The two that I saw fail were identical to this.
www.pghoffroad.com
My SOA Build
Recovery Gear Basics
My BUDGET York OBA Install
Budget Welding Cart
Carling Contura Switch Panel
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline   Reply With Quote
Unread 06-30-2012, 09:29 AM   #19
Anticanman
Anticanman's Avatar
Coincidentally, on the other side of the country, I saw one fail that was set up like this too. The guy had better luck wrapping electrical tape around the shaft afterwards.
Luck favors the prepared
Originally Posted by squarelight94 View Post
You're the Oprah of jeeps, slap your name on it and it sells like hot cakes!
Originally Posted by jbolty View Post
I would like to thank everyone who thanked Anticanman.
Originally Posted by egodfrey
Well canada is a different story this is american talk here silly :rofl:
Anticanman is offline   Reply With Quote
Unread 09-26-2012, 12:42 PM   #20
sardog211
Can anyone post a write up on how to install the napa seal into the front axle? I have 2 of them and need to install it. I saw a write up but when I went back to find it, the search engine retrieved nothing. Any help would be great my iPhone seems to be against searching properly.
Unread 09-26-2012, 01:52 PM   #21
H3RTCH
Live Free or Die.
H3RTCH's Avatar
The factory location for the seal is in the CAD housing, on the wheel side. When most people perform the one-piece shaft swap, they place the seal in the centersection, where the seal is on non-CAD axles. When I did this swap, I put that seal in the factory location inside the CAD housing. This was mainly because of inexperience in vehicular maintenance, and I was incredibly uncomfortable with taking the differential out. The shafts I bought were rust free and smooth, and that swap was over 30,000 miles ago, with no leaks. The write-up is here.
BTW, I apologize for the thumbs down, my internet browser is screwing up and shifting pictures to the left.
2004 Jeep WJ Grand Cherokee Overland - My DD
1991 Jeep YJ Wrangler 4.0L, D30 Solid Shafts <--- For Sale
1988 Jeep MJ Comanche 4.0L - Dad's
1999 Jeep WJ Grand Cherokee 4.0L - Mom's
H3RTCH is offline   Reply With Quote
