1997 jeep YJ - JeepForum.com
post #1 of 13 Old 02-24-2010, 10:37 AM Thread Starter
boyscout2207
1997 jeep YJ
does anyone know what manuel 5 speed trasmission came in the 1995 jeep YJ with the 2.5 l 4 cyl engine? and if so could I swap that engine for a 4.2 L 258 AMC?
boyscout2207 is offline
post #2 of 13 Old 02-24-2010, 10:42 AM
Dado99TJ
Junior Member
Dado99TJ's Avatar
Do you mean 1987? A 1997 would be a TJ not a YJ and I'm pretty sure all 2.5's with a manual came with the AX-5. The AX-5 likely won't hold up behind a 4.2 or a 4.0
Nightcrew member #331
Blue Jeep Club member #332
Dado99TJ is offline
post #3 of 13 Old 02-24-2010, 10:44 AM
95jy
in 87 was it a ba-10
95jy is offline
post #4 of 13 Old 02-24-2010, 10:49 AM
timatoe
timatoe's Avatar
Not behind the 4 banger, behind the 4.2 yes
Originally Posted by YJ FAQ
Transmissions
Manual transmissions
AX-5 - Aisin 5-speed behind the I4 '87-'95
timatoe is offline
post #5 of 13 Old 02-24-2010, 10:49 AM Thread Starter
boyscout2207
i mment 1995 thanks though do you have any sugestions to a new tranny?
post #6 of 13 Old 02-24-2010, 10:54 AM
95jy
the ax-15 is a good swap, thanks timatoe for the correction
95jy is offline
post #7 of 13 Old 02-24-2010, 10:55 AM Thread Starter
boyscout2207
what would be the recomended drivetrain for a 4.2 L in the 95 YJ? T-18? NV4500? transfercase?
post #8 of 13 Old 02-24-2010, 10:56 AM Thread Starter
boyscout2207
will the AX-15 swap into the existing transfercase?
post #9 of 13 Old 02-24-2010, 11:00 AM
Dado99TJ
Junior Member
Dado99TJ's Avatar
I don't think so; I think the splines are different. I think most back up an AX-15 with a NP231J T-case.
Dado99TJ is offline
post #10 of 13 Old 02-24-2010, 11:02 AM Thread Starter
boyscout2207
thanks alot for your help
post #11 of 13 Old 02-24-2010, 11:04 AM
Dado99TJ
Junior Member
Dado99TJ's Avatar
Check this thread to find out your stock specs and look in the FAQ for write-ups on transmission swaps. Lots of good info in the FAQ.
Dado99TJ is offline
post #12 of 13 Old 02-24-2010, 11:24 AM
timatoe
timatoe's Avatar
If you're gonna do an engine swap, get a 4.0 so you've got injection. Seems backward to me to go to the 4.2.
timatoe is offline
post #13 of 13 Old 02-24-2010, 11:29 AM
Leans93
She's my density...
Leans93's Avatar
95' 2.5L to 4.2L swap would be a headache. Swapping to a 4.0L is a better engine and a much easier swap. Check out the link in my sig for info on the 2.5 - 4.0 swap.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
1997 Jeep Cherokee 6 cylinder engine swap into a 97 Jeep Wrangler? Maverick14 TJ Wrangler Technical Forum 2 08-23-2010 09:26 AM
1997 jeep tj weight cmc1 TJ Wrangler Technical Forum 10 09-27-2009 11:58 AM
jeep tj 1997 2.5 ax-5 kyle_waters TJ Wrangler Technical Forum 4 05-04-2008 02:06 PM
New Jeep Owner (when I say new I mean 1997 TJ) bpdurb0 TJ Wrangler Technical Forum 3 06-25-2007 09:25 PM
I am BACK! Just got my new Jeep! A 1997 TJ, 4.0 Pawpower1995 TJ Wrangler Technical Forum 6 02-21-2005 08:47 PM
