1997 ax15 - JeepForum.com
post #1 of 4 Old 02-11-2011, 02:05 PM Thread Starter
TippmannA-5
1997 ax15
K so i just picked up this AX15 from a guy for free I started taking it apart and it looks so freaking nice, that i was surprised. The guy said it was stiff in first gear. Maybe he was just a wuss, but if not. How do I tell if a synchro is worn out. Thanks for all the help in advance!!
I'm growing rather fond of driving a vehicle with the aerodynamic qualities of a brick.
Yellow Jeep Club Member #4.2
Every time a bird craps on my jeep, I sit on my front porch and eat scrambled eggs to show them what i'm capable of!
TippmannA-5 is offline
post #2 of 4 Old 02-11-2011, 05:01 PM
4.7stroker
Probably just needed an oil change.
This may help you in the near future......http://www.billhughes.com/temp/AX15.pdf
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 4 Old 02-12-2011, 01:31 AM Thread Starter
TippmannA-5
Dwayne
Thanks for that, but I do not need help taking it apart. I really just want to know what a good and a bad synchro in an AX15 look like....
post #4 of 4 Old 02-12-2011, 08:29 AM
4.7stroker
The PDF should have specs that you can use to check things out. There are several places you will need to measure clerance. The synchroes have a cone that wears, measuring the clearence tells you the condition.
May the Jeep gods be with you.
Dwayne
[url]
[url]
1989 , ax15 , jeep , transmission , wrangler
late ax15 to eraly ax15 swap questions baltimorebiker YJ Wrangler Technical Forum 3 03-24-2010 06:01 PM
Is the Shifter from a YJ AX15 the same as TJ AX15? capone1680 TJ Wrangler Technical Forum 4 11-16-2009 06:31 PM
AX15 Help BeerJ YJ Wrangler Technical Forum 6 05-19-2008 07:49 PM
Making a 2WD AX15 into a 4WD AX15 JeepsOLot YJ Wrangler Technical Forum 6 05-14-2008 09:15 PM
ax15 into an 89 yj? insane1 YJ Wrangler Technical Forum 2 07-01-2005 11:17 AM
