1995 YJ wont crank after i get it up to temp - Page 2 - JeepForum.com
post #16 of 44 Old 11-10-2013, 02:08 PM
YJames90
YJames90's Avatar
Check the timing
My 2.5 to 4.3 swap thread
YJames90 is offline
post #17 of 44 Old 11-10-2013, 04:58 PM
Siva283
Originally Posted by YJames90 View Post
Check the timing
This
Sent from my SPH-L300 using JeepForum
Ask me how I know...
Siva283 is offline
post #18 of 44 Old 11-10-2013, 07:25 PM
YJames90
YJames90's Avatar
Originally Posted by Siva283 View Post
This
bad timing makes it almost impossible to start and makes it feel and sound like a dead battery
YJames90 is offline
post #19 of 44 Old 11-11-2013, 07:50 AM
Siva283
I was agreeing with you. The only part missing though now that I think about it is he should be getting some back firing. But I still think he needs to check time once it is up to temp and has been there for a solid 15 minutes are so so everything in the engine bay is up to temp as well.
Siva283 is offline
post #20 of 44 Old 11-11-2013, 09:05 AM
WDNewman
Originally Posted by dbody View Post
is there a way to test this?
Couple of ways. When it warms up and refuses to restart, wet down the cps area with a hose. Give it a few minutes to cool down. If that is the problem, it should start right up.
These things are not terribly expensive, costing around $35 at your local parts store and are easy to install.
And oh yeah, I've heard that this failure does not throw a code, but can't verify this as my '89 doesn't believe in codes.
WDNewman is offline
post #21 of 44 Old 11-11-2013, 09:27 AM
Siva283
The CPS should throw a code during the no start condition but like you believe it wont always. Cooling the sensor down is also not definitive. If it works you know its bad but if you cool it and it still doesn't work that doesn't confirm nor deny the issue. Also if it was CPS it would not have spark during the no start condistion. If that sensor is not working it shuts off spark. Check the timing. Its easy you can rent tools and it will answer some questions.
Siva283 is offline
post #22 of 44 Old 11-11-2013, 10:02 AM
Que89YJ
Try this. Get it warm so you have the no start and try and crank it over to make sure you have the no start. Then disconnect the battery and count to 10 and reconnect it to reset the ecu back to open loop and try and start it.
It is really unusual to have spark and spray starter fluid and get no ignition.
Do you still have a catalytic converter on it? Did you replace the plug wires? Check your fuel pressure to see if it is running high. 31 psi idle, 39 psi with the vacuum line to the regulator removed and it should hold presure above 20 psi for 20 minutes.
Last thing I can think of would be a bad pickup sensor in the distributor throwing off timing but I dont see how the issue can be hot/cold with a bad pickup.
Que89YJ is online now
post #23 of 44 Old 11-11-2013, 04:34 PM Thread Starter
dbody
Thanks for all your responses!
here is what i got. I chnaged out the CTS and i am now able to start it after up to temp but it is a hard start. for instance if i get it up to temp then shut off and start right after i shut off it starts right up.
BUT if i wait say 5 minutes i go and try to start it again and i have to pump gas or either ease down on gas then it is a rough start but once it gets back runing fine (30 secs) or so it is good to go..
I repeat this process of shutting off starting right back with no problem no gas pushing just fires right up.
but again if i wait 3 or 4 minutes it is another hard start (gas pumping etc..)
I also change the Rotor and the Dist Cap. As AlWAYS i appericiate your help and look forward to hearing from you or anyone else.. also the plugs are in correct place and there are only major changes when pulling 4,5,6??
Thanks! (still confused)
dbody is offline
post #24 of 44 Old 11-11-2013, 05:56 PM
Que89YJ
Look at my post.
Fault codes:
Mean Max pics of everything:
No Start:
post #25 of 44 Old 11-11-2013, 08:50 PM
Siva283
Listen to Que man he is the resident guru he will get ypu straight
Siva283 is offline
post #26 of 44 Old 11-12-2013, 05:21 AM
YJames90
YJames90's Avatar
I know I was just adding to it
YJames90 is offline
post #27 of 44 Old 11-12-2013, 06:50 AM
Siva283
Siva283 is offline
post #28 of 44 Old 11-12-2013, 01:55 PM Thread Starter
dbody
where is the vacuum line to the regulator located?
dbody is offline
post #29 of 44 Old 11-12-2013, 02:27 PM
Que89YJ
It's on the front of the fuel injector rail.
Fault codes:
No Start:
post #30 of 44 Old 11-12-2013, 05:24 PM Thread Starter
dbody
ok this is what it read i started and let idle and it was on/around 50 PSI
took the vacuum line off of regulator and nothing changed....
shut off and the pressure immediately dropped to 0 PSI...
Does this tell you anything (for sure)??? is regulator bad and should it hold pressure with it completely cut off? IF so what does this tell me?
Thanks for your help!!
dbody is offline
