1995 YJ wont crank after i get it up to temp - JeepForum.com
post #1 of 44 Old 11-07-2013, 01:03 PM Thread Starter
dbody
jeep will run perfect in the morning but if i go to the store 15 miles down the road and come back shut it off and try to crank it will not... like i said i have been working and racking my brain about this. please any suggestions will be a blessing!
i have replaced:
starter
Battery
Plugs
Fuel FIlter
Coil
Stater
Throttle Position sensor
also ran injector cleanor through it
i am getting fuel and fire...
it has a slight stutter or miss at idle and low RPMs
once i get up to certain rpm it seems to run fine.
the stutter just started happening (worse) after i replaced the TPS
, but when drove 10 / 15 miles will not crank until at least the next morning..... (blows my mind)
thanks for any and all tips/hints/fix/tricks!!
dbody is offline
post #2 of 44 Old 11-07-2013, 02:28 PM Thread Starter
dbody
oh and thanks guys in advance for future help/advise!!
dbody is offline
post #3 of 44 Old 11-07-2013, 04:31 PM Thread Starter
dbody
anyone have any insight or have dealt with this issue before? Im about to loose my mind!
dbody is offline
post #4 of 44 Old 11-08-2013, 07:24 AM Thread Starter
dbody
PLEEEAASEEE Someone respond and give me some advise
dbody is offline
post #5 of 44 Old 11-08-2013, 07:27 AM
Schaef81
Does it crank but not turn over? Or just turn the key and nothing? If it cranks and cranks but doesn't turn over it could be the CPS. Looks like by the list of parts already replaced that would logically be the next one
BDS - Spartan - AtoZ Fabrication - Borgeson HD - USA Standard - BFGoodrich
Schaef81 is offline
post #6 of 44 Old 11-08-2013, 07:47 AM Thread Starter
dbody
yes it cranks and cranks and cranks but never hits. Not even with starter fluid. by CPS are you meaning crankshaft postion sensor? if so how come this would not effect it when it is cold and does run? thanks for the reply!
dbody is offline
post #7 of 44 Old 11-08-2013, 09:24 AM
Siva283
No crank shaft sensor would keep it from firing at all. What you need to do first is pull the codes with the key trick. It sounds like the pick up in the distributor to me but pull the codes first period. Stop throwing parts at it and troubleshoot properly. We will help you. Its a lot cheaper and you learn more about your engine.
I am sure Que will be along shortly. He is a master at the electronics.
Ask me how I know...
Siva283 is offline
post #8 of 44 Old 11-08-2013, 09:39 AM Thread Starter
dbody
i have pulled the codes and came up with bad or short in alternator (cant remember what the number was). this lead to one of the things i replaced (Battery) the second code it threw was 52 (O2 sensor) which lead me to replace (TPS, after discussion with parts store guy and mechanic friend)
after replacing what i have i am now getting NO codes???
that is the first thing i check after replacing and clearing codes (key trick)
thanks for the response and i look forward to more help!!
dbody is offline
post #9 of 44 Old 11-08-2013, 09:55 AM
Siva283
How many miles are on your rig?
Siva283 is offline
post #10 of 44 Old 11-08-2013, 10:20 AM Thread Starter
dbody
a little over 92,000
dbody is offline
post #11 of 44 Old 11-08-2013, 12:23 PM
Siva283
When it is not starting are you sure your still getting spark at the plugs during this time?
Siva283 is offline
post #12 of 44 Old 11-08-2013, 12:38 PM Thread Starter
dbody
yep i have checked several times on several if not all plugs.
dbody is offline
post #13 of 44 Old 11-10-2013, 06:15 AM Thread Starter
dbody
can anyone else chime in on this i am stumped!
dbody is offline
post #14 of 44 Old 11-10-2013, 06:21 AM
WDNewman
Crankcase position sensor. Stops working when hot. When it cools down works fine. Typical problem.
WDNewman is offline
post #15 of 44 Old 11-10-2013, 06:34 AM Thread Starter
dbody
is there a way to test this?
dbody is offline
