1995 YJ Wiper Issues - JeepForum.com
post #1 of 12 Old 10-12-2013, 04:21 PM Thread Starter
johnscag
Hello, I have a 1995 Wrangler YJ , recent purchase (with new wiper motor says past owner). Wipers stop working the other day. I dropped it off at a friends shop, he said he thinks its the motor but I need to do it since the top has to come off. He also said they are working, I was like what? but sure enough they did work when I got in it.
I was messing with it today , key on, wipers running and checking to see if the would stop and they did. I jiggled the harness under they dash and no change, I also checked the ground on the motor and it was tight and no change when I tried to move it. When they stop the washer motor does not pump.
I went to turn on the turn signal and they started again...
I am guessing the switch in the column is bad ?
Thank you for any input !
johnscag is offline
post #2 of 12 Old 10-13-2013, 07:31 AM
Rino1425
Sounds like the switch in the colum is bad. Mine does that too. Cheap part, but takes a bit of time and patients to fix. You will need to pull the steering wheel off to replace. I think i bought my new turn signal switch for about 30 bucks from morris. its a mopar one.
Rino1425 is offline
post #3 of 12 Old 10-13-2013, 10:28 AM
czjeeper
My washer switch is intermittent.
It won't act up often enough to find the fault.
Let me know what you find.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #4 of 12 Old 10-15-2013, 08:03 PM Thread Starter
johnscag
Can anyone confirm :
1. A bad motor does not affect the washer pump working?
2.When I switch goes you will loose everything? I now have nothing but turn signals etc..
Thank you!
johnscag is offline
post #5 of 12 Old 10-16-2013, 01:52 PM
Rino1425
Im not sure about the motor question, but i know my switch is bad for the wipers, but my turn signals still work
Rino1425 is offline
post #6 of 12 Old 10-16-2013, 02:15 PM
shinysideup69
YJ wiper issue
Late reply but thought this may help others.
For my 93 YJ, it has had a tendency to over rotate the wiper arms and not be able to return back across the windshield. The problem with mine was that the pivots (both sides) have got a broken limiter or stop. You can Fab. a small sheet metal piece to repair it or try and replace the pivots. At this time Mopar does not build it any longer but I have found some still in captivity at some dealers. 3 to be exact. The salvage yards are of no help on this as well. The P/N is: 55154891.
shinysideup69 is offline
post #7 of 12 Old 10-16-2013, 05:18 PM Thread Starter
johnscag
And does your washer still pump?
johnscag is offline
post #8 of 12 Old 10-17-2013, 08:17 AM
shinysideup69
Not sure. I have rectified the wiper problem so I cannot tell you for sure.
post #9 of 12 Old 10-17-2013, 08:42 AM
Que89YJ
The washer pump is a seperate circuit.
Que89YJ is online now
post #10 of 12 Old 10-17-2013, 07:12 PM Thread Starter
johnscag
Do you have any idea why both would fail at the same time and then start working again at the same time?
I am thinking switch or relay.
Thank you
johnscag is offline
post #11 of 12 Old 10-17-2013, 10:06 PM
Que89YJ
Switch. Relay is separate.
Fault codes:
Mean Max pics of everything:
No Start:
post #12 of 12 Old 10-18-2013, 06:24 PM Thread Starter
johnscag
ok, I have ordered a switch, Thank you !
johnscag is offline
