1995 yj taillight and turn signal issues - JeepForum.com
post #1 of 6 Old 05-04-2014, 06:53 PM Thread Starter
FrostyBryan
Hi there my name is Bryan and I own a 1995 jeep yj. ive used jeep forums alot for almost everything and anything I had to do to my jeep and I've been having this problem for a while, and to sum it up.. The brake lights wont turn on when I press the brakes, and also my turn signals/hazards wont turn on either. I've changed and replaced the bulbs, then replaced and checked all the fuses. Changed the flasher relay switch and hazard switch. And its still broken? I don't know what else to do.
https://www.youtube.com/watch?v=h-xPBVkpx5w for the video
FrostyBryan is offline
post #2 of 6 Old 05-04-2014, 07:21 PM
Caboose89
Make sure your tail lights are grounded.
1989 Sahara. SOA, 35's, Locked.
Caboose89 is offline
post #3 of 6 Old 05-04-2014, 07:34 PM
Mark05059
the tail lights ground through the mounting studs. Clean the studs and where they mount to the tub.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 6 Old 05-10-2014, 11:19 AM Thread Starter
FrostyBryan
Ok thank you I will try that
post #5 of 6 Old 05-10-2014, 10:48 PM
dukeryder
after you clean up the contact surfaces with some scotch brite, squirt some WD-40 on the mounting surfaces and put a Dielectric grease on the bulb's contacts. That should help. I have a small utility trailer and I had one side acting the same way, no tail light, brake, or signal, I cleaned up the contacts and ******d it with WD and everything works great now.
dukeryder is offline
post #6 of 6 Old 05-11-2014, 07:27 AM
Jpiombo
1987 YJ Wrangler
I just had the same problem.
I replaced the left rear turn signal, because it was rusting out.
Made sure all the bulbs were the right ones. I had 2057's in the front turn signals.
Retraced all the wires and found that I had a frayed wire on the right rear side of the jeep and it was causing everything to go haywire.
Check you fuses.
Hope this helps
The difference between my vehicle and yours is that my vehicle won a war.
Jpiombo is offline
1995 , brake , jeep yj , taillight
