1995 YJ Stalling Problems - Page 3 - JeepForum.com
post #31 of 37 Old 03-16-2011, 02:02 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by Que89YJ View Post
Yep, I still think its the ecu if there is no CEL.
Agreed. If the CEL light is in place and has been tested for continuity (they take way more than 12 volts to 'blow' trust me) and the socket has been tested for voltage so you knowe that this circuit has not been cut before the dash, if you get no CEL light at startup then the ECM has probably got bad capacitors.
At this point you have nothing to lose by replacing the capacitors do you? Can't do it get a buddy who can solder, but with a little bit of practice you can do this job.
Soldering is easy. All you have to do is count seconds in your head when soldering something. Say two 14AWG wires that have been twisted together.. Get the soldering iron hot, clean the tip with a damp sponge, tin it with some solder...not too much. Make contact with wires, now once you see some movement (3 seconds at the most) add some solder..not too much get off of wire after two seconds. Admire your beautiful soldering job! You should see the outline of the twisted wires like they were two lovers under a wet sheet!
To de-solder joint using an ear bulb syringe. Compress the syringe before you melt the joint. Once the joint solder is liquid suck out the excess solder with the compressed syringe by letting the air out of it.
Another method for de-soldering joints is with some small metal braided material. Again you get the solder liquid and lay down the braided material. It will wick up excess solder.
There are several very good posts here in JF concerning this whole capacitor replacement process.
Again I ask you if the ECM is NG what have you got to lose by 'operating' on yours?
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #32 of 37 Old 04-18-2013, 04:45 PM
drew27racing
You might check the ignition coil, this happened to my 95 4.0 yj when i put a faulty ignition coil on it
drew27racing is offline
post #33 of 37 Old 08-03-2015, 04:14 PM
Jeepsnkd
I am having the same or similar problem, However, my CEL does not come on when my 95/2.5L Wrangler stalls but it does work when I start the ignition.
It originally started when driving and would stall out, then start after letting it sit for a minute or two.
Then it wouldn't start at all and I replaced the crank shaft sensor and had the coil replaced, but not the cap or rotor (It had a tune up just last year and isn't driven too often)
I tried starting it in the garage earlier and it stalled twice before it started to run continuously.
I took it for a test drive after that and at low RPM it ran OK, but when I made a U-Turn and hit the gas to speed up, it started to buck. I backed it into the garage and at that point it cut out several times, and knocked before bucking to a stall. The exhaust smelled terrible with no smoke, (I'm guessing from burning too much fuel) but it definitely wasn't a burning oil smell.
I'm mostly curious about the CEL working fine except when it initially stalls. Any help would be appreciated.
Jeepsnkd is offline
post #34 of 37 Old 08-03-2015, 05:17 PM
Que89YJ
Did you check the bulb?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #35 of 37 Old 03-19-2017, 04:54 PM
FrankenJ33p
Mine was stalling when at temp and at speed
Hi guys, I'm new to the forum and not sure if this helps. also noticed these threads were a few years old, but incase anyone does a search I hope my experience can help.
bought my son a 93 yj with 120k on it and shortly after doing a soa lift when I was at speed and the jeep was at operating temp, it would act like someone hit a kill switch and flip it right back on. I began to replace stuff like the distributer, cap, rotor, coil, wires and plugs. didn't solve the problem. then did the o2 sensor, throttle position sensor, and the MAP sensor. thought that did it but after a couple of times driving, it acted up again. then I did the Crank shaft sensor. that solved the problem. So now I will probably replace the remaining sensors just because I have nearly replaced them all.
FrankenJ33p is offline
post #36 of 37 Old 03-19-2017, 05:46 PM
Que89YJ
Make sure to replace the mat sensor
Fault codes:
No Start:
Que89YJ is offline
post #37 of 37 Old 03-19-2017, 06:51 PM
1991YJisLife
^this. The wires for the map sensor on my buddies Jeep went bad on our way down to Utah. It would act like a kill switch when driving but being a manual, the Jeep would fire back up after a little while with momentum.
The sensor is located on the right side of the engine towards the back. It's on the intake manifold to be specific. Wiggle the wires around in that area and see if the Jeep dies. If wiggling the wires doesn't kill it, then check the sensor itself next
Edit: oops, look like you already fixed the problem. I should've read the whole thing... And not assumed mat was a typo for map
1991YJisLife is offline
stalling , wrangler , YJ
1995 YJ Stereo install problems ezdan YJ Wrangler Technical Forum 16 02-03-2012 12:52 PM
4.2 problems after stalling in water... dbikers YJ Wrangler Technical Forum 1 06-17-2007 06:19 PM
Stalling problems 4wheeler98 TJ Wrangler Technical Forum 6 03-14-2007 11:43 PM
Stalling problems in 88 PhoenixEML YJ Wrangler Technical Forum 32 04-11-2005 02:19 PM
Stalling problems soxfann YJ Wrangler Technical Forum 6 11-20-2004 06:18 PM
