1995 yj heater and gauges help - JeepForum.com
post #1 of 5 Old 07-22-2013, 01:07 AM Thread Starter
jerecho1995
Hey guys, I'm new to this I have a 95 yj with the 2.5 and my heater and fuel gauge have stopped working. Has anyone else encountered this problem is there a cheap, relatively quick fix?
jerecho1995 is offline
post #2 of 5 Old 07-22-2013, 04:43 AM
SeanB95YJ
pull the center gauge panel and check the board (and connectors) on the back... look for any crustly green/white corrosion. while not 100%, this is the most common culprit when it's more than one gauge at a time going bad.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 5 Old 07-22-2013, 11:03 AM
Sagerist
Sagerist's Avatar
I had the same problem at one point. My issue was as was said above, i cleaned out the circuitry very carefully and reinstalled it. I also had issues with my fuses being loose in the fuse block. I replaced the fuses and cleaned out the connections where the fuse sits and now i dont have any issues with any of my gauges or the heater.
Colorado Jeep Club Member #286
89 YJ 2.5L
OME 36R's, Bilstein 5100's, Bserk 5/8" shackles, 33x10.5 BFG's on 15x8
09 KK Sport 4X4
235/75/16 GY Slnt Armor
CB 2' Firestik
Fire/EMS Radio
Sagerist is offline
post #4 of 5 Old 07-27-2013, 07:47 AM
ronnorman6
had the same problem with corrosion cleaned it up and then everything went back to normal would check that before u start looking into wiring problems
ronnorman6 is offline
post #5 of 5 Old 07-27-2013, 10:43 PM Thread Starter
jerecho1995
Cleaned it up and works perfect. Thanks guys
