-   -   1995 yj heater and gauges help (http://www.jeepforum.com/forum/f12/1995-yj-heater-gauges-help-1552040/)
jerecho1995 07-22-2013 02:07 AM
Hey guys, I'm new to this I have a 95 yj with the 2.5 and my heater and fuel gauge have stopped working. Has anyone else encountered this problem is there a cheap, relatively quick fix?
SeanB95YJ 07-22-2013 05:43 AM
pull the center gauge panel and check the board (and connectors) on the back... look for any crustly green/white corrosion. while not 100%, this is the most common culprit when it's more than one gauge at a time going bad.
Sagerist 07-22-2013 12:03 PM
I had the same problem at one point. My issue was as was said above, i cleaned out the circuitry very carefully and reinstalled it. I also had issues with my fuses being loose in the fuse block. I replaced the fuses and cleaned out the connections where the fuse sits and now i dont have any issues with any of my gauges or the heater.
ronnorman6 07-27-2013 08:47 AM
had the same problem with corrosion cleaned it up and then everything went back to normal would check that before u start looking into wiring problems
jerecho1995 07-27-2013 11:43 PM
Cleaned it up and works perfect. Thanks guys
The time now is 03:57 AM.
