1995 YJ fuel leak problem - JeepForum.com
post #1 of 8 Old 06-13-2013, 04:02 PM Thread Starter
castorriver
Every now and then my jeep will leak a steady stream of fuel in the rear left tire area. When it happens, it's a steady drip and will leave a good sized pool if I idle for a minute. If I turn off the jeep and restart it, sometimes it will leak, sometimes it won't. Most of the time it runs fine, no leaks. I have the 4cyl engine. Any ideas?
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #2 of 8 Old 06-13-2013, 04:10 PM
jokerchief462
Check the lines to the fuel filter. Mine did that they needed to be replaced weather rot.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 8 Old 06-13-2013, 04:10 PM
idaholtby
This sound like it could be a couple of items... Check the filler tube and vent. Also, given the location, check your fuel filter connections. It resides at the driver's side inside the frame rail at or just before the rear wheel. If this problem is persistent, it should be easy to locate the source.
idaholtby is offline
post #4 of 8 Old 06-13-2013, 05:26 PM Thread Starter
castorriver
Okay I'll change the fuel filter first and see if that helps. I bought it last year and haven't replaced it yet.
post #5 of 8 Old 06-13-2013, 05:53 PM
glturner39
Mine was doing the same thing. It was the fuel line going from the tank to the fuel filter. Mine wasn't pushed on all the way just had to loosen clamp, push it on and tighten clamp. Yours might just be rotten though and need replacing. Don't forget to depressurize the fuel line before messing with t or you will get a gasoline bath. You can find the fitting on the fuel rail it looks kind of like a AC fitting. Oh mine has the 4.0 so don't know if it is similar or not.
glturner39 is offline
post #6 of 8 Old 06-13-2013, 06:04 PM
idaholtby
I won't argue with replacing the fuel filter as you do not know the history of it, but please look for pre-existing leaks before doing so. This way you have a bit of confidence of fixing the original problem if you see the issue before you do the work.
post #7 of 8 Old 06-13-2013, 07:54 PM Thread Starter
castorriver
Just thought of another thing, for a while I ran the gas down and kept it below 1/2 tank thinking that would solve the problem, but it happens at no matter what level. Right now the tank is full and the gas hasn't leaked for a few drives.
post #8 of 8 Old 06-13-2013, 08:01 PM
NHfireLJ
NHfireLJ's Avatar
Similar problem and it was loose clamps by the filter and return line... New clap. problem solved
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
