1995 YJ 2.5l Power Steering Bracket Mounting Help! - JeepForum.com
post #1 of 5 Old 06-09-2011, 04:29 AM Thread Starter
PilotPat24
Hello,
Just finishing up a rebuild on a 1995 YJ 2.5l. I am having trouble mounting the power steering bracket back up. I know the front two bolts bolt up the water pump but where the back bolt mount to? Does it mount to the motor mount with the stud on the top? For the life of me, I can't get this bracket to line up! Any suggestions?
All help will be appreciated.
PilotPat24 is offline
post #2 of 5 Old 06-10-2011, 01:57 PM
bharris68
Daily Driver
There is a bracket behind the pump that extends from the block up to the Intake, I believe.
More..
Have a look around the backside - do you have pictures of both sides of the bracket?
In Blue here:
Let me know if that helps
bharris68 is offline
post #3 of 5 Old 06-10-2011, 03:18 PM
sandmanfl
I am in the middle of replacing a water pump so I had to loosen the power steering pump. i am sending a couple of pics I also have a95 YJ 2.5. Be careful when reinstalling bolts ether my torque wrench lied or I am getting stronger NOT broke a bolt on the water pump what a pain had to drill and easy out and alot of prayers..Does your 95 have aseerate powere sterring tank if so these pics should help. Ignore the rust on bracet i did.
sandmanfl is offline
post #4 of 5 Old 06-10-2011, 04:05 PM
bharris68
Daily Driver
Nice pictures - you kids and your fancy new-fangled serpentine belts!!!
post #5 of 5 Old 07-01-2011, 10:57 PM
Megapher
We have a 95 YJ with a 4.0l 6 cyl and are having some serious issues with the bracket for the power steering pump. We have 5 brackets, all the same and can't figure out how it would mount to the intake. Doesn't seem to line up properly and the last bracket we got was off a 94 yj, same intake, same engine. Any suggestions?
Megapher is offline
95 YJ power steering bracket vikes09 YJ Wrangler Technical Forum 10 10-27-2010 07:45 AM
Power Steering Bracket lovs2fly YJ Wrangler Technical Forum 3 10-03-2007 12:43 PM
Power Steering Conversion 1995 4cyl SeattleTJ YJ Wrangler Technical Forum 16 11-18-2006 02:53 PM
Pic of 92 4.0 power steering bracket tr6 YJ Wrangler Technical Forum 2 10-07-2006 08:55 AM
Power Steering conversion for 1995 YJ SeattleTJ YJ Wrangler Technical Forum 4 02-25-2006 10:36 PM
