1995 yj 2.5 engine runs rough above 2k rpms when cold - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1995 yj 2.5 engine runs rough above 2k rpms when cold
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread Yesterday, 02:20 PM   #1
tvm9177
My 95 yj ' s 2.5 engine is running rough when I drive it cold above 2k rpms. It just started doing this yesterday after a trip to hollister hills svra. I did go through a but of mud and water but I can't figure out what's wrong. Any ideas or thoughts are much appreciated I'm a broke college student so I'm trying to avoid taking it to a shop to find and fix the problem.
tvm9177 is offline   Reply With Quote
Unread Yesterday, 02:23 PM   #2
tvm9177
Forgot to add that by rough I mean the power jumps and it lurches/surges in power is the best way I can describe it.
Unread Yesterday, 10:26 PM   #3
cody413
I have the same engine and I had the same problem. It ended up being throttle position sensor. And temp sensor and it cleared up. Been 6 months still nothing. Who knows if that's your problem. But I just figured I'd put my .02 in for ya
cody413 is offline   Reply With Quote
Unread Yesterday, 10:27 PM   #4
cody413
I just changed both idk which one fixed it btw
Unread Yesterday, 10:29 PM   #5
tvm9177
Thanks I appreciate it I'll look into replacing them both do you know roughly how much they cost?
Unread Yesterday, 10:50 PM   #6
cody413
Cheap. I think I spent 50 or so at advance with a lifetime replacement. Good luck. Post back if you figure it out.
