1995 wrangler YJ problem - JeepForum.com
post #1 of 13 Old 03-05-2013, 12:38 PM Thread Starter
ChandlerH205
It keeps running hot we've tried nearly everything.
Replaced the radiator, replaced the coolant hose, cleaned the coolant jug, replaced the thermostat.
HELP!!!
ChandlerH205 is offline
post #2 of 13 Old 03-05-2013, 03:56 PM
PA_YJ19
What about the water pump, if its not circulating the fluid none of that other stuff is going to do its job either. Usually if ur overheating the water pump is ur culprit. Have u changed it as well?
PA_YJ19 is offline
post #3 of 13 Old 03-05-2013, 06:55 PM
Que89YJ
How hot does it get and when does it get hot?
Que89YJ is offline
post #4 of 13 Old 03-05-2013, 07:27 PM
b_a_mech
To add to this...are your signs of overheating steam, overflow bottle filling up??? Or are you just going by the gauge??
Gauge or sensor could be bad?
Have you checked it with a thermometer or with a digital temp sensor?
Just throwing it out there
BUILT NOT BOUGHT #602 / ZOMBIE RESPONSE TEAM #40 / USN HULL #196
b_a_mech is offline
post #5 of 13 Old 03-05-2013, 07:31 PM
gunshw301
My gauge reads just below the red when it's actually warmed up and the true temp is a normal 210. Had to put a wired temp gauge behind the thermostat to figure it out. Like others said, do you have any actual signs of it over heating, besides the gauge?
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #6 of 13 Old 03-05-2013, 07:35 PM Thread Starter
ChandlerH205
We are gonna try the water pump y'all I appreciate it ill let y'all know if it doesn't work.
post #7 of 13 Old 03-05-2013, 07:56 PM
gunshw301
Could be the fan clutch. Hard to say without any actual info, good luck.
post #8 of 13 Old 03-05-2013, 09:34 PM
dauster500
1987 YJ Wrangler
Stop replacing parts and wasting your time & money.
04 5spd 4.0 TJ DD, 87 3spd auto 4.0 yj
Gotmudcnj4x4.org
dauster500 is offline
post #9 of 13 Old 03-28-2013, 08:28 AM Thread Starter
ChandlerH205
We fixed it Thank guys!!
post #10 of 13 Old 03-28-2013, 08:35 AM
gunshw301
What turned out to be the problem?
post #11 of 13 Old 03-28-2013, 08:45 AM Thread Starter
ChandlerH205
Well, after replacing the water pump, thermostat, radiator, hoses and coolant jug..
It was an air bubble lol.
post #12 of 13 Old 03-28-2013, 08:48 AM
Que89YJ
The flush kits make it real easy to get the air out. Glad you got it going!
Que89YJ is offline
post #13 of 13 Old 03-28-2013, 08:51 AM Thread Starter
ChandlerH205
Thanks again y'all
