1995 wrangler rebuild wont start! help - JeepForum.com
post #1 of 23 Old 04-17-2013, 01:41 PM Thread Starter
wyattwj123
hey everyone i got a 1995 2.5 l wrangler and the engine threw a rod a week ago so i ripped the engine out and brought it to the rebuild shop it got done being rebuilt and i got done installing everything and when i tried to turn it over the starter just makes a constant clicking noise and wont start..The starter is brand spankin new and so is the battery! i tryed to turn the crank by hand with a ratchet and it was extremely hard to turn so i think that has something to do with it! this is my everyday driver so i need to figure this out!thank you
wyattwj123 is offline
post #2 of 23 Old 04-17-2013, 01:45 PM
flcracker
Pull the plugs and see if it turns over by hand that way....
Assuming shop has everything all done with assembly lube and you primed the oiling system??
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #3 of 23 Old 04-17-2013, 02:28 PM Thread Starter
wyattwj123
i will try that with the plugs and if it cranks what does that mean?! and yes but i dont even know what priming the oil system is hahah
post #4 of 23 Old 04-17-2013, 05:36 PM Thread Starter
wyattwj123
Anyone????????????? Any help would be great thank you!!
post #5 of 23 Old 04-17-2013, 06:09 PM
Que89YJ
It sounds like the starter is binding. You need to check that they gave you the right starter. Drop the starter and see if it actuates. If it does then. Pull the plugs so you are not dealing with the engines compression and turn it with a wrench on the crank pulley. If it is hard to spin the issue is in the engine.
Que89YJ is offline
post #6 of 23 Old 04-17-2013, 06:14 PM Thread Starter
wyattwj123
ok ill do that tomorrow but the starter is the same one i had before that is brand new but the new remaned one could be bad i guess but will do thank you
post #7 of 23 Old 04-17-2013, 06:28 PM
Que89YJ
Lets hope so. That u=is what Flcracker was talking about.
Que89YJ is offline
post #8 of 23 Old 04-17-2013, 06:37 PM Thread Starter
wyattwj123
Yea I really hope so but the engine is freshly rebuilt should be no issues but ill try it an what is priming the oil?
post #9 of 23 Old 04-17-2013, 07:03 PM
flcracker
More experience with small block cbevys back in the day but priming the oil system is putting a gutted distributor down to engage oil pump and driving the oil pump with a drill to pump oil throughout the engine..
post #10 of 23 Old 04-17-2013, 07:29 PM
pete1991YJ
You can do the same thing with an old screwdriver in an electric drill. Its a pretty good idea too.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #11 of 23 Old 04-17-2013, 08:07 PM Thread Starter
wyattwj123
Won't it work if I remove the spark slugs and try and turn it over?!
post #12 of 23 Old 04-17-2013, 08:20 PM
pete1991YJ
I wonder if this is one of those got the backside of a pulley hung up on the block somewhere. I remember a guy had that problem last year. It totally baffled him because nobody expected the obvious to check.
post #13 of 23 Old 04-18-2013, 06:58 AM Thread Starter
wyattwj123
Pulled the plugs it was a bit easier to turn the crank but the starter did the same thing :/
post #14 of 23 Old 04-18-2013, 07:25 AM
pete1991YJ
Hrmm, the starter is new and so is the battery... what about the cables? and the connectors? A cable thats corroded inside will do that. Also is it grounded? If so, are the grounds clean and tight? The engine needs a ground as big as the starter cable.
post #15 of 23 Old 04-18-2013, 07:48 AM Thread Starter
wyattwj123
Yes everything is good I just got another starter and wired it up when I put the ground on the battery the starter just started spinning all the wires are connected correctly
