1995 wrangler flooding out with gas RUNS and BACKFIRES at idle quits 1 min of running - JeepForum.com
post #1 of 14 Old 02-13-2013, 05:04 PM Thread Starter
xpdude
1995 JK Wrangler
1995 wrangler floods out with gas. Runs semi smooth then starts to POP POP BACKFIRE then it dies out. pulled plugs and all but two were soak with gas. what would cause this? it has a new ECU fuel-pump plugs cap rotor. crank position sensor. checked compression has 150PSI first three cyl then 160 4th cyl. FUEL PSI 35 idle. REMOVE vacuum line @ regulator and jumps to 40PSI. I think that checks out ok. SPARK is yellow / white. Is that weak? I though the coil may need to be replaced? Resistance checked out on the coil. what else could cause it to flood? could the timing be off and still have compression?
xpdude is offline
post #2 of 14 Old 02-13-2013, 05:28 PM
Mark05059
at a guess... sounds like your injectors are leaking/plugged and are dribbling gas in instead of spraying in like it should.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 14 Old 03-25-2013, 11:49 AM Thread Starter
xpdude
1995 JK Wrangler
ok. update!!! ECU is bad and not working right. runs but skips and backfires. I TRY THE UNIT IN SOMEONES JEEP AND SAME SYMPTOMS! i bought the new one from www.autocomputerexchange.net. hopefully the alternator burned it out from bad brushes. i noticed the radio don;t turn on and the gas gage isn;t working. is that controlled by the ECM?
xpdude is offline
post #4 of 14 Old 03-25-2013, 02:43 PM
idaholtby
So the rig runs fine now with the new to you ECU? Only now you have issues with the gas gauge and radio, not before?
idaholtby is offline
post #5 of 14 Old 03-29-2013, 07:17 PM Thread Starter
xpdude
1995 JK Wrangler
acually no. i think the dist is off, won't start. i installed it according to hynes and it just backfires, fire order is right. i got it to run on 1 cyl only.
xpdude is offline
post #6 of 14 Old 03-30-2013, 05:23 AM
Que89YJ
Fuel gauge is independent. Set the timing. Then clear the ecu by disconnecting the battery and recheck codes.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #7 of 14 Old 03-30-2013, 02:51 PM Thread Starter
xpdude
1995 JK Wrangler
1995 wrangler non running need help
i bought this 1995 YJ non running. It won,t run and pops and backfires like the timing is off. we set the new timing chain according to the book: line the two dots side by side, rotate and count 20 links on the chain dot to dot. i have compression, 150psi cyl 1-2-3- and 4 160psi. we set the distributor on the cyl 1 compression stroke, and set the harmonic balancer to the (0). still is isn't running. with the engine at TDC (0), the cam dot is 360 off, is that right? Do you guys have a picture of the distributor installed with the rotor position as the engine is at top dead center? it appears to me the camshaft could be broke, because at top dead center the cam dot is 360 degrees away from the crank dot.
IMG_20130330_150221.jpg   IMG_20130330_150302.jpg   IMG_20130330_150303.jpg   IMG_20130330_150309.jpg
xpdude is offline
post #8 of 14 Old 03-30-2013, 02:57 PM Thread Starter
xpdude
1995 JK Wrangler
this is how we installed the chain. the crank has a very faint dot but its there and lined up.
xpdude is offline
post #9 of 14 Old 03-30-2013, 03:09 PM Thread Starter
xpdude
1995 JK Wrangler
so i am wondering what we are doing wrong. the 1st pic is where we put the distributor at TDC (0) on the harmonic balancer.
xpdude is offline
post #10 of 14 Old 04-01-2013, 02:05 PM Thread Starter
xpdude
1995 JK Wrangler
can anyone shed some light on distributor installation? what about the timing chain? at compression its 360 off dot at the top?
xpdude is offline
post #11 of 14 Old 07-05-2013, 03:39 PM
Badyj7
I'm having a similar problem did u ever figure it out
Badyj7 is offline
post #12 of 14 Old 05-08-2014, 11:45 AM Thread Starter
xpdude
1995 JK Wrangler
i believe the cam was snapped off somewhere i have yet to pull out the cam. in the mean time i got a new engine with 160k runs good has the chain rattle though.
xpdude is offline
post #13 of 14 Old 05-08-2014, 12:34 PM
Que89YJ
Cam was snapped and he still got good compression? weird.
Que89YJ is offline
post #14 of 14 Old 05-16-2014, 02:31 PM Thread Starter
xpdude
1995 JK Wrangler
the dist was off a tooth wouldn't go to 3 oclock position
xpdude is offline
