1995 temp sensor - JeepForum.com
post #1 of 15 Old 11-22-2011, 10:37 AM Thread Starter
moonshinefuel
1995 temp sensor
I am looking for a coolant Temp sensor, I believe there are two on the 1995 with 2.5 engine. If so, I need the small one on the back of the top of the cylinder head. Dealerships are telling me the small sensor on the top of the back of the cylinder head does not exist. I see one there. Does anyone have a part number, or info on this sensor, I think it is for the Temp gauge as mine is not working.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #2 of 15 Old 11-22-2011, 10:43 AM
94chb
the temp sensor is on the thermostat housing
94chb is offline
post #3 of 15 Old 11-22-2011, 11:54 AM
Jeepfan1
ditto. I just looked at my 95 2.5 and I see no sensor on the back just the one in the thermostat housing up front
/l , [____],
|---L--OlllllllO-
()_) ()_)==O=)_)
Jeepfan1 is offline
post #4 of 15 Old 11-22-2011, 12:02 PM
tdewit
The 95 2.5 has a temp sensor on the drivers side / firewall corner of the head. NAPA part number ECH TS3001
tdewit is offline
post #5 of 15 Old 11-22-2011, 12:48 PM
Apollo12227
OP, I'll post a link to my thread. The dealer should be able to pull the part for you, I bought mine at the dealer because three separate senders from three separate auto parts stores all read 30* hot. Maybe the nappa part referenced above will read correct but advance and autozone both left me reading 30* hotter than I was actually running.
http://www.jeepforum.com/forum/f12/y...ffect-1035824/
Above is my thread, it took 117 posts to figure out I was getting sold inaccurate temp senders. I spent nearly 1K on the cooling system including radiator, flex-a-light fan, water pumps, countless thermostats, and the list goes on. You should unscrew the sender and slap it on the desk in the dealership and tell him to tell you it doesn't exist again. Maybe you are wording it wrong... It's the "temp sender for the dash gauge, it has one purple wire going to it." If you have to drive the jeep there then drag is idiot a** outside and show him. I hate dealing with the dealership, some are great but most are nearly incompetent.
Apollo12227 is offline
post #6 of 15 Old 11-22-2011, 12:49 PM
Apollo12227
The sensor on the t-stat housing is for the ECM, the sender (one purple wire on the back of the head) goes to the gauge. I assure you that if you have a 2.5, ho4.0 you have a temp sender on the back of your head with one wire going to it. If you don't believe me, unplug the temp sensor at the tstat after your engine heats up and I'll bet you that your gauge still works.
post #7 of 15 Old 11-22-2011, 01:46 PM
94chb
nope my 4.0 only has a sensor on t-stat housing and none on back of head. now i know what your talking about cause ive seen a few xj's with the little white single wire sensor in the back driver side of the head inbetween the intake mainfold and valve cover..
94chb is offline
post #8 of 15 Old 11-22-2011, 02:39 PM
Apollo12227
Your profile says you have a 4.2, which is not a 4.0... The OP has a Chrysler so it will have a sender at the back of the block. Especially a 95. What vehicle make and year is this 4.0HO without a sender at the back of the head?
post #9 of 15 Old 11-22-2011, 03:01 PM
94chb
if you looked at my profile you would have seen SWAPPED TO 4.0 H.O Fuel injected and also swapped from auto to manual
i pulled everything from a 91 wrangler and installed it into my 89
94chb is offline
post #10 of 15 Old 11-22-2011, 03:20 PM
Apollo12227
Weird, maybe because it was such an early year 4.0? I dunno all I can say is a 95 Chrysler 2.5 has a sender on the head lol.
post #11 of 15 Old 11-22-2011, 03:24 PM
94chb
yea i got a 92 xj sittin here in the yard that im putting a 98 motor in and the 92 engine had the temp sensor on the back of the head, but the 98 didnt so i took it off the 92 and installed it onto the 98.
94chb is offline
post #12 of 15 Old 11-22-2011, 06:58 PM Thread Starter
moonshinefuel
When dealerships get confused on this, that's pretty bad. They couldnt help me. Thanks for all the help here. I will post 3 images in the next 10 mins or so. I purchased these today at Kragen/Orielly auto parts. The small sensor is tucked under the fuel injector rail rear side of the cylinder head, drivers side, threading streight down into the cylinder head. They called it a "light sensor", it is for the gauge. It's kind of hard to see unless you are looking for it, and know where it is. Why they call it a light sensor, not sure why, but they do, at kragens. It was approx 12 dollars. The third image will be the one we all see, the one in the thermostat housing. On the boxes, are the part numbers.
Below is the sensor that
Threads into the thermostat
Housing. Over 20 dollars.
Bow Hunting
post #13 of 15 Old 11-22-2011, 08:08 PM
Apollo12227
The one with the little white cap is obviously the winner. The other like you said is for the housing. They are under the assumption that you have a dummy light setup above a gauge setup? I dunno I never try to explain dealership madness lol. Anyways, hope it reads accurate! Oh and PS, be careful handling the sensor as a socket will knock (break off) off the plastic part where the wire cOnnects very easily.
post #14 of 15 Old 11-09-2013, 02:50 PM
MCI
Hi,
This post helped me. I found the sensor at AutoZone:
Temperature Switch
Duralast TU236
$13
MCI is offline
post #15 of 15 Old 11-09-2013, 03:22 PM
Apollo12227
Glad to hear.
Keep in mind I tried about 4 different temp sensors from advance and autozone and all of them read 30* hot than what the actual engine temp was.
I had to buy a sender from the dealership in order to get my gauge to read accurate. Spent nearly $1,000 on the cooling system chasing an imaginary overheating problem because of those dang temp senders. Not sure if the inaccuracy is nation wide or not, but several senders from both advance and autozone read hot.
Crankshaft Position Sensor 1995 YJ 4 cyl. YJBully YJ Wrangler Technical Forum 4 11-17-2010 06:09 PM
No second temp sensor Anonymity TJ Wrangler Technical Forum 4 02-05-2010 04:38 PM
Where is the temp. sensor on a tj nolo263 TJ Wrangler Technical Forum 4 08-07-2007 10:41 PM
Temp Sensor / Coolant Temp Sending Unit malone_ge YJ Wrangler Technical Forum 1 03-01-2007 09:41 AM
Temp sensor sandman'sjeep YJ Wrangler Technical Forum 20 01-20-2006 10:02 AM
