1995 jeep yj starting problems - JeepForum.com
post #1 of 7 Old 07-11-2013, 08:05 PM Thread Starter
Maloni
My 1995 jeep yj 2.5l 5 speed was sitting for almost 10 years.
First thing I did was remove old fuel and did a complete tune up (oil change,fuel filter,rotor dist. Cap plugs wires.)
Added lucas fuel treatment( full bottle not sure if it was a mistake :s)and fresh fuel and hand cranked motor before starting.
Would turn over but wouldn't fire so I checked fuel pressure to learn the fuel pump was done so I dropped the tank and replaced the pump and she fired up ran a little rough and then smoothed out.
Now after about 50 km of trouble free driving over about a weeks time one morning she didn't want to start but did after a few attempts but now doesn't want to start at all.
Here is what I have troubleshooted
-fuel pressure is 35psi
-has lots of spark
-new map sensor (it threw the code)
-I squirted a tiny shot if starting fluid in the intake and she fired and ran like absolute **** with a fair bit of smoke but stayed running (maybe injectors are the clogged but no code shows.
I'm stumped any help would be greatly appreciated.
Maloni is offline
post #2 of 7 Old 07-11-2013, 08:49 PM
XJ93
Pull the injectors and clean them up, throw them back in with new o-rings.
XJ93 is offline
post #3 of 7 Old 07-11-2013, 09:39 PM Thread Starter
Maloni
Any special advice for cleaning them?
Maloni is offline
post #4 of 7 Old 07-12-2013, 05:19 AM
XJ93
I used 3M fuel injector cleaner on mine and scrubbed the heck out of them with an old toothbrush.
XJ93 is offline
post #5 of 7 Old 07-12-2013, 05:51 AM
Siva283
Your fuel pressure is also high. Might want to check into the regulater. What color was the smoke?
Ask me how I know...
Siva283 is offline
post #6 of 7 Old 07-12-2013, 08:54 AM Thread Starter
Maloni
What should the pressure be at I was told 35 was rite on the money. How do I check the regulator thanks
Maloni is offline
post #7 of 7 Old 07-12-2013, 09:28 AM
Siva283
It should be 31 psi during idle and cranking. It should be 39 at wide open throttle. To test this hook a fuel pressure gauge up and fire up the engine. With it running at idle not the pressure. Now disconnect the vacuum line with it still running.(The vacuum line plugs into a round disc like thing(Thats the regulator) on the grill side of the fuel rail) When you disconnect that vacuum line it should jump to 39 psi.
Siva283 is offline
