1995 jeep wrangler yj 2.5l has no spark need help!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1995 jeep wrangler yj 2.5l has no spark need help!!
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiWarn, Smitybilt, Engo, Rugged Ridge Winches at CCORIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-11-2015, 10:29 AM   #1
Flipjr94
I just purchased a 1995 jeep wrangler yj 2.5l 4 cylinder, it has a 5 speed manual transmission and for the past 2 weeks Iv been trying to figure out why I cannot get a spark. I have replaced the crankshaft position sensor, coil, full distributor (which I was told has the camshaft sensor inside), and I just changed out the PCM too. And still I cannot get a spark. I also have no power to the coil and have been tracing wires and grounds to make sure everything is ok, and so far it all checks out. And all the grounds and powers that go to the PCM are 100%. Does anyone else know what is going on, or have any suggestions?
-thanks Andrew
Flipjr94 is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 01:37 PM   #2
jason m
Nothing but the facts
jason m's Avatar
Moved to YJ section.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt....
jason m is offline   Reply With Quote Quick reply to this message
Unread 01-21-2015, 09:27 AM   #3
Que89YJ
Did you figure it out or do you still need help?
Que89YJ is offline   Reply With Quote Quick reply to this message
