1995 jeep wrangler 2.5L 5spd manual tran stock - JeepForum.com
post #1 of 23 Old 01-03-2012, 12:24 PM Thread Starter
roguelephant
What is the best transmission fluid for my 5 speed manual transmission. thank you in advance.
al
roguelephant is offline
post #2 of 23 Old 01-03-2012, 12:37 PM
J-Mox
You need to post this in the "YJ Technical Forum".
Go to the top of the page and click on "Forums", scroll down about 1/3 of the way and there is a section for "Models", "Jeep Wrangler Forums", "YJ Wrangler Technical Forums".
Post there and they should be able to help you out! Welcome to the forums!
2004 Wrangler X, 6-cylinder, 5-speed, Dana 30 w/ARB, Alloy USA front shafts, Dana 35, 2" BB, 1" BL, OME shocks, Brown Dog MML, UCF Ultra High-Clearance Skid, Lo-Pro Mount, SYE, Pro Comp Adj. Control Arms, Savvy Gas Tank skid, JKS Quick Disconnects, Rock Hard Sliders, 31" BF Goodrich KM2's on Ravine wheels, Hard Top, Bestop Soft-top, Bestop Safari Top
2010 Moab Trip Thread with JeepForum Members
Dont hate on the guy that keeps his Jeep clean....
Hate on the guy that doesn't get his Jeep dirty....
J-Mox is offline
post #3 of 23 Old 01-03-2012, 12:38 PM
SnowYJ
1988 MJ Comanche
10w-30
I go to college and I drive a Jeep.
SnowYJ is offline
post #4 of 23 Old 01-03-2012, 01:36 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Nothing too expensive, the AX5 you have will probably start losing gears soon...
Seriously, here is the fluid specs from Alldata:
Transmission
Manual 75W-90 GL5
Automatic [03]
Transfer Case Dexron II/III
Front/Rear Axle [01]
Power Steering 4118055 [02]
Brake System DOT 3
[01] -- Standard duty front & rear differential, 75W-90 GL5;
Rear differential of models w/ trailer towing package, 80W-140 GL5;
Models w/ limited slip differential, add 2 ounces of friction modifier.
[02] -- Chrysler/Jeep-Eagle part number.
[03] -- AW4 auto. trans., use Mercon;
w/ 30H or 32H auto. trans., use ATF Plus 7176 or equivalent.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #5 of 23 Old 01-03-2012, 02:28 PM
Xpress
AllData does not lie...
All about that unibody life.
Xpress is offline
post #6 of 23 Old 01-03-2012, 04:38 PM
Mark05059
in this case it does... 10w30 is whats reccomended in it now.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #7 of 23 Old 01-03-2012, 05:00 PM
Xpress
AllData is not wrong, it is manufacturer specifications taken straight from the fishes mouth, and it's updated as the manufacturer updates. Assured 100% accurate as even dealerships use it.
Xpress is offline
post #8 of 23 Old 01-03-2012, 06:38 PM
pasinbuy
No, you are wrong here! Sorry!
10x30 motor oil is what is currently recommended. It is close to 75x90w gear oil. Why the mfg. changed I do not know!
To be honest the only difference that I can see is the detergent. The weights are the same. Weight in gear oil and motor oil have different scales. A 75x90w motor oil would be like thick cold honey.
pasinbuy is offline
post #9 of 23 Old 01-03-2012, 08:44 PM
Xpress
Sorry, AllData is not wrong. It hasn't ever been wrong, peoples lives may depend on it. The information above might be outdated, however, probably taken from the site years back.
Xpress is offline
post #10 of 23 Old 01-03-2012, 09:20 PM
leftlanetruckin
XJ on 37's
Guess it's down to the Op then.
I always go with Alldata myself, as it is indeed pretty much a FSM.
If it makes any difference though, I just checked the FACTORY service manual for the 1994 YJ and XJ, and it states the exact same thing for the AX5 transmission
Martin
post #11 of 23 Old 01-03-2012, 09:22 PM
leftlanetruckin
XJ on 37's
Nope. That information came from Alldata from a subscription I made @1month ago for Dave's YJ build. Alldata is indeed updated from the Factory though, listing recalls, and so on.
Martin
post #12 of 23 Old 01-03-2012, 10:23 PM
MDCustom
Instead of arguing about it, why not just ask the dealer? You don't have to buy it from them, but they don't charge for a phone call- YET!
MDCustom is offline
post #13 of 23 Old 01-04-2012, 01:08 AM
yjluv
synchromesh!!!
yjluv is offline
post #14 of 23 Old 01-04-2012, 06:18 AM
grandboost98
isnt there a thread going around with information from the engineers explaining why they switched to 10w30?
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #15 of 23 Old 01-04-2012, 07:53 AM
JEEP_Nut1218
http://www.jeepforum.com/forum/f9/fa...cities-489932/
AX-5 5 speed manual - 3.3 quarts 75W-90 GL3, 75W-90 GL4, or 10W30 (NOT GL5 or GL5 compatible as incorrectly stated in some of the manuals)
'90 YJ with some stuff
I'm a pic whore, get over it.
JEEP_Nut1218 is offline
New Jeep Wrangler Unlimited section? Flyingbrass JeepForum Announcements 4 12-16-2004 03:10 PM
