1995 2.5L Transmission/Axial oil questions - JeepForum.com
post #1 of 3 Old 01-20-2012, 11:06 PM Thread Starter
Ochosi
So im planning on doing a full oil swap tomorrow on all my axial, transmission, transfer case, and changing to synthetic for my engine. I know my engine needs 10W-30, the transfer case needs ATF +4, I have a question though regarding my axial's and transmissoin
My Chilton's guide says that I should used GL-5 for my transmission but on some write ups here on the site it says I should use GL-4 or GL-3. Issue is that orileys and Napa out here in sacramento dont really offer a GL-4 or GL-3 specific oils, but do offer GL-5 oils that conform to GL-4/GL-3 standereds. Should I go with these Oil's or order some GL-4 oils from online? I have also heard that full synthetic GL-5 oils can be used, is this true?
Another question, do my axils require a GL-5,4,3 spacific oil as well, just like my transmission? Or would placing SAE 80W-90 GL-5 not cause any harm?
Thanks guys!
Ochosi is offline
post #2 of 3 Old 01-20-2012, 11:58 PM
greyyj
Just go with the GL-5 it works fine
greyyj is offline
post #3 of 3 Old 01-21-2012, 07:37 AM
Mark05059
use 10w30 in the transmission (cheaper the better) and GL5 in the front and rear axles.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
Ball joint allowable axial play? secretspy711 JK Wrangler Technical Forum 2 10-29-2011 08:41 AM
Help with Automatic Transmission Coolant Hose Part - 1995 Wrangler (pics) mattwmc YJ Wrangler Technical Forum 2 08-11-2011 04:53 PM
1995 YJ 2.5L Valve Cover Gasket questions. GJeepFan YJ Wrangler Technical Forum 3 05-12-2011 07:12 AM
Questions on 1991-1995 Jeep Wrangler GJeepFan YJ Wrangler Technical Forum 33 01-03-2011 01:09 PM
1995 jeep wrangler yj automatic transmission and transfercase for sale solobericl5 YJ Wrangler Technical Forum 2 04-25-2010 06:03 PM
