1995 and 1994 rear end question - JeepForum.com
post #1 of 14 Old 12-16-2011, 10:19 AM Thread Starter
JUNKYARDDOG01
hello all
i need to replace my rear axle for 1994 wrangler. i found someone with a 95 wrangler 6cyl...are they compatible?
JUNKYARDDOG01 is offline
post #2 of 14 Old 12-16-2011, 10:21 AM
scubamc
Yes if the gear ratios ate the same.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #3 of 14 Old 12-16-2011, 10:23 AM
moonshinefuel
Yes, as long as it is the same gearing as the front axle.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #4 of 14 Old 12-16-2011, 10:51 AM Thread Starter
JUNKYARDDOG01
pardon my ignorance, which gear ratio has to be the same my front or his?? can you explain it simpler terms... please
post #5 of 14 Old 12-16-2011, 11:03 AM
Que89YJ
The gear ratio for the front and rear must be the same or your drive line is going to try and spin at different rates as the gears in the axle spin. The Jeep came stock with 2 diffwerent gear ratio's depending on the engine. The 2.5L came stock with a 4.11 and the 4.0L came with a 3.07. Many people change the gears when they go to a bigger tire as well. If the axles come out of a yj with the same engine and they are stock then any axle will work.
Que89YJ is offline
post #6 of 14 Old 12-16-2011, 11:15 AM
bikerdude
1987 YJ Wrangler
The 2.5 5 speed YJ's all had 4.10 axles but the 4.0 YJ's had several axle ratios, I believe 3.07 & 3.73. You need to find out what your axles are in your jeep and get one with the same ratio so that when you are in 4wd the front and rear tires turn at the same speed.
bikerdude is offline
post #7 of 14 Old 12-16-2011, 11:46 AM Thread Starter
JUNKYARDDOG01
can i check on axle itself for the gear ratio?? is it stamped somewhere or can i tell from the vin#?? basically the donor rear end has to be the same as what i have in there now??
post #8 of 14 Old 12-16-2011, 12:05 PM
bill8bud
Look for a tag on the diffcover secured by the bolts.
bill8bud is offline
post #9 of 14 Old 12-16-2011, 12:07 PM
Que89YJ
I forgot about the 3.73 on the 6's as well. You can't tell by the vin. You need to count the # of rotations. or count the teeth.
Que89YJ is offline
post #10 of 14 Old 12-16-2011, 12:09 PM
Que89YJ
If the tag is there. There are also suppose to be tags on the door. Upgrade to the 8.8 Ford axle. They are everywhere, cheap, and way stronger.
Que89YJ is offline
post #11 of 14 Old 12-16-2011, 12:27 PM
bill8bud
you can also look for the tag on the front diff
bill8bud is offline
post #12 of 14 Old 12-16-2011, 12:35 PM
1998zj
If it is just axles or spider gears. Change those parts and you don't need to take the axle out of the Jeep.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #13 of 14 Old 12-17-2011, 06:35 AM Thread Starter
JUNKYARDDOG01
ok i looked for a tag or any indicator of gear ratio...nothing there where else can i look?? or find the gear ratio
post #14 of 14 Old 12-17-2011, 06:49 AM
NHfireLJ
NHfireLJ's Avatar
Why do you need to swap out the axle? Maybe there are other options, give us more info..
Read this ... http://www.jeepforum.com/forum/f9/fa...-ratio-615380/
Step #3 to figure out gear ratio...
Search function is your friend
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
1995 YJ Rear Seat Brackets crawdawg YJ Wrangler Technical Forum 4 07-14-2009 08:43 PM
1994 Wrangler still a Dana 35 in the rear? fishwater2 YJ Wrangler Technical Forum 6 06-22-2009 01:09 AM
1994 ford dana 60 (rear) jeepin1995 YJ Wrangler Technical Forum 25 04-22-2008 07:14 PM
1994 rear diff ? skeletor YJ Wrangler Technical Forum 1 09-03-2005 08:26 AM
Rear receiver hitch for 1995 YJ kbertsch YJ Wrangler Technical Forum 4 10-24-2004 03:19 PM
