1994 YJ, starter will turn over but not start - JeepForum.com
post #1 of 9 Old 08-24-2011, 04:38 PM Thread Starter
steveg917
1994 jeep yj won't start, turn key and the starter will turn over but won't start. Before if i turned the key to the on position and waited about twenty minutes and there would be a clicking noise coming from the relay box and the fuel pump would prime and it would start right up. Now when i try to start it I wont even get the clicking and it turns and turns but wont start. Replaced relays. Replaced ignition switch. But no luck. Think its either the crank position sensor or the brain, from what i can find online, but I'm not sure. The crank position sensor is a pain to get to and the brain is a little pricey so i was hoping to get some input before i undertook either. Please help, this jeep is my pride and joy and its just caused constant problems.
steveg917 is offline
post #2 of 9 Old 08-24-2011, 04:49 PM
Mazdarx
Have you made sure the starter works properly? This happened on one of my Jeeps, the starter would turn but it wasn't turning over the engine. So try and turn it and verify it is turning the engine over, either hit the key with it in gear or have somebody watch the engine to be sure it's turning. Other than that I have no ideas.
-My business, being self-employed rocks.
91 Yj Renegade, lifted, built 4.0L, 33's etc
Mazdarx is offline
post #3 of 9 Old 08-24-2011, 05:10 PM
bigbossd1030
That's your computer, your capacitors need to be replaced. Do a search on capacitor replacment there is a writeup. If you know how to solder that will help. It will be under 20 bucks
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 9 Old 08-24-2011, 05:36 PM Thread Starter
steveg917
the starter does turn the engine, when it is in gear it will jolt forward. Would replacing the computer as a whole fix the problem? Not very good at soldering, and a body of mine has a couple scrap jeeps a could salvage one off of
post #5 of 9 Old 08-24-2011, 05:45 PM
stenyeart
I would at least pull your computer apart and check it out. If you can see bad capacitors, replacing the computer will do the same thing as fixing it.
It definetly sounds like the computer to me.
stenyeart is offline
post #6 of 9 Old 08-24-2011, 05:50 PM
oldtime_ironman
Does it have spark? Also, does the "check engine" light come on when you put the key in and "on" without starting it? If the check engine light comes on then most likely the computer is OK. If no spark, I would replace the crankshaft position sensor first, and re-set the computer by disconnecting the battery for 5 mins.
If all that fails, *then* I would look into the computer.
oldtime_ironman is offline
post #7 of 9 Old 08-24-2011, 08:20 PM Thread Starter
steveg917
that is actually a part i left out.. after letting it sit for 20 minutes with the key in the on position the check engine light and the "shift up" light would come on, how ever now neither will come on nor will the clicking happen. Also i looked up how to read codes by turning the key on, off, on, off, on and waiting for the flashes but got nothing
post #8 of 9 Old 08-24-2011, 08:31 PM
oldtime_ironman
Pretty sure the computer is dead then. There's a cheap and easy way to fix it tho, one of the guys gave a "how to do it" with pics. Check out this link:
http://www.jeepforum.com/forum/f12/c...ors-ecu-492597
It's a pretty common prob. You can do it yourself for like $5 instead of spending on a new one. Just make sure to follow the directions and pay attention to detail. You can get the parts you need at any Radio Shack in the US - you need three 220 uF, 35 volt electrolytic capacitors and a soldering iron.
Hope that helps!
post #9 of 9 Old 08-25-2011, 08:22 AM
nembudonna
If you can get one for free and you know it's good, why not screw with yours?
nembudonna is offline
clicking , ignition switch , jeep , relay , YJ
1994 jeep wrangler 2.5l starter bolt geekboy31 YJ Wrangler Technical Forum 2 03-12-2011 11:26 AM
Turn key, hot ground wire from battery, starter casing gets hot, jeep will not start sloan74 YJ Wrangler Technical Forum 9 06-26-2010 08:21 PM
1994 YJ - 4CYL Starter Replacement - Bosch chimmychanga YJ Wrangler Technical Forum 2 04-19-2009 09:57 AM
Steering Problem Help! left turn fine.... start to turn right & there is a delay. opie2l TJ Wrangler Technical Forum 2 06-23-2008 01:00 PM
1994 yj wont start whiteyj1994 YJ Wrangler Technical Forum 25 09-18-2007 08:17 AM
