1994 YJ Oil Problem - JeepForum.com
post #1 of 3 Old 08-24-2011, 03:55 PM Thread Starter
PeterSyz
1994 YJ Oil Problem
I have a '94 YJ that I drive almost everyday. The oil pressure is always low even after filling it with oil. I check it after just 50 miles and there's no oil left. There is no leak, I am sure of it.
Has anyone ever experienced this or know what might be causing this?
Plaese let me know, Thanks!
PeterSyz is offline
post #2 of 3 Old 08-24-2011, 04:23 PM
clarkjdg
clarkjdg's Avatar
Well is it smoking? Because if it isnt leaking out that really just leaves one option "Burning" and low oil pressure usually means problems to start with. Check your tail pipe and see what its like at the rear.
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #3 of 3 Old 08-24-2011, 07:47 PM
damian H
Do you have pcv system hooked up? With out a crank case ventilation system that works properly your engine could use alot of oil.
damian H is offline
oil , oil leaking , oil pressure
1994 YJ Blinker Problem sherrodk YJ Wrangler Technical Forum 3 06-04-2011 05:45 AM
1994 4.0 Code 24 Problem iowajeepers YJ Wrangler Technical Forum 1 04-10-2011 02:50 PM
1994 jeep yj problem ncem2 YJ Wrangler Technical Forum 2 07-18-2009 10:55 PM
1994 Starting Problem iowajeepers YJ Wrangler Technical Forum 16 06-12-2008 03:26 PM
1994 YJ 2.5L coolant leak problem jbanks25 YJ Wrangler Technical Forum 4 06-18-2006 12:12 PM
