1994 YJ Oil Pressure goes down - JeepForum.com
post #1 of 4 Old 05-01-2013, 12:16 PM Thread Starter
sherrodk
I have this problem where my oil pressure will be between 40 and 50 when its first started, than after about 10 minutes of driving it will drop down to 0 to 10. It will stay there. I have changed the oil and filter, and the oil sending unit but has not helped. Any ideas. Also do not see any oil leaks at all.
1994 YJ 2.5 with 120,000 miles
sherrodk is offline
post #2 of 4 Old 05-01-2013, 07:25 PM
RustedWrangler
Mine drops to about 25-30. Probably time for both of us to think about replacing oil pumps.
www.RCPFA.com
RustedWrangler is offline
post #3 of 4 Old 05-02-2013, 10:50 AM
cojab
I have the same issue. I read a thread on here a couple of weeks ago about another member that had the same issue also. I'm sure I wont remember this completely correctly but the jest of his thread was that while troubleshooting he removed his sending unit I believe, cleaned the oil passages and problem solved. Gauge has read correctly at about 40psi since. He had feedback from others on that thread that did the same fix with same results. Worth a shot before dropping the pan for a pump.
Hopefully someone else has better details or the link to that thread for you. You might try a quick search for it also. I know the info is in here somewhere. Next time I find it I wont be such a knucklehead and I'll bookmark it since I need to do this as well.
cojab is offline
post #4 of 4 Old 05-02-2013, 11:30 AM
skyj
It could be a number of things, start with the easy one others have suggested. It could so be your main and rod bearings on the crank or the cam bearings. Usually that's the case when you start up and you get high pressure cause the oil is not as thin as it is when it was a cold motor, then as the motor warms and the oil thins a bit and you drop pressure.
build thread:
skyj is offline
