1994 YJ new shocks, clunking when hitting bumps - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1994 YJ new shocks, clunking when hitting bumps
Jeep Wrangler Complete Gear Upgrade Kits with Installs andZone Offroad Body and Suspension Lift Kits, Brackets, DiscBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 03-20-2015, 06:11 PM   #1
Akt2467
I replaced all four shocks on my Wrangler YJ that I had recently bought. I hadn't had the chance to really drive it much before buying it so I'm not sure if this issue was happening before replacing all shocks or not. Front 2 shocks were from AutoZone, back 2 were from 4x4terrain i believe because Autozone's were too short in the back. All are on and good, but when I drive it and hit bigger bumps I get a good clunking sound from the front as with the back. Now it's not possible that the shocks are too short correct? If they were too short they would have never fit to begin with?
What could be causing the clunking sound, it's puzzling me...
Akt2467 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 07:34 PM   #2
TSEJEEPERS
I would start out looking at your track bars. Look at the mounting points and grab the bar and shake it real good.
It is pretty common for them to come loose.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 07:39 PM   #3
Akt2467
I don't have a front track bar on it currently, could that be causing it? Could it be my ball joints?
Unread 03-20-2015, 07:41 PM   #4
TSEJEEPERS
Has the front track bar been completly removed?
Unread 03-20-2015, 08:29 PM   #5
Rafthegiraffe
I hear a similar sound and it's because the frame were the shackles are mounted is rusted and when hitting a bump will cause it to move. Idk if you've checked the mounts on the leaf springs but while your under there take a look
Rafthegiraffe is offline   Reply With Quote Quick reply to this message
Unread 03-21-2015, 11:34 AM   #6
Anticanman
The Thunder Chunky
Anticanman's Avatar
Check all your bushings and make sure your track bars are adios'd.
Luck Favours The Prepared
Originally Posted by rambo3489 View Post
Listen to what the canman says. You don't have to take it all word for word. But at least listen to the man. He knows his ****. Its a no BS straight to the point realistic approach to things. You may not like it. But someday you might have an Anticanman moment. Like you just had. I know I have. Hell I had 2 last week.
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 03-21-2015, 07:22 PM   #7
Akt2467
Yes the front track bar has completely been removed at this point. The leaf springs have some rust but aren't that that bad though
