1994 yj heart transplant - JeepForum.com
post #1 of 14 Old 06-02-2010, 07:55 PM Thread Starter
nickaldrich
I have a 94 yj 2.5l 5 speed, i work at a larger junk yard and have plenty of 4.0L out of cherokees and grand cherokees.. i have my engine,trans,tcase,driveshafts,radiator out of a salvaged 94 wrangler but i got there to late and they sold the harness and ecm... my question is does anyone know if i can use any other ecm and wiring harness????
nickaldrich is offline
post #2 of 14 Old 06-03-2010, 09:03 AM Thread Starter
nickaldrich
Nobody?? please help
post #3 of 14 Old 06-03-2010, 09:32 AM
Que89YJ
Yes you can. The XJ OBD1 and the YJ are the same. Make sure that you are getting it for the right engine. 91 and later under the hood are the same but you will run into complications with the IP wiring between the years. Especially the bulkhead, ignition switch, and cluster. What year YJ are you starting with? Your in Adrian Michigan?
Que89YJ is online now
post #4 of 14 Old 06-03-2010, 10:03 AM
rusteehawk71
You can use the ECM that is already in your Jeep. All you need is the engine harness from the donor vehicle, it will plug right into your ECM and your good to go.
rusteehawk71 is offline
post #5 of 14 Old 06-03-2010, 10:04 AM Thread Starter
nickaldrich
1994 yj is whats its going into... i did live there.. now im in livonia and work in ypsilanti
post #6 of 14 Old 06-03-2010, 10:14 AM Thread Starter
nickaldrich
the 2.5l ecm will run the 4.0l???
post #7 of 14 Old 06-03-2010, 10:16 AM
Que89YJ
No, that was what I was saying. It has to be motor to motor for the ECM. The drivers are different
post #8 of 14 Old 06-03-2010, 10:19 AM
Que89YJ
If you need any help let me know. I am downriver and work in Auburn Hills. There have been a bunch of part outs you can get harnesses and ECM from in Craigslist and on the Great Lakes 4x4 forum.
post #9 of 14 Old 06-03-2010, 10:20 AM Thread Starter
nickaldrich
Engine is out of a 1994 xj.. so its just plug and play?? my jeep is a 94 2.5l stick and the xj is a 4.0l auto.. i am taking the wiring harness from the xj and the ecm from it too... will it just plug in at the bulk head and will my gauges work??? thanks again
post #10 of 14 Old 06-03-2010, 10:26 AM
Que89YJ
No, there are some wiring differences. Close but no cigar. Your wiring harness will work. You just need to swap the ECU and add 2 injector wires. The auto trans had the nuetral saftey switch so you jumper those pins on the ECU and you should be good to go. No need to swap the wiring harness at all.
post #11 of 14 Old 06-03-2010, 10:51 AM
Que89YJ
If you need help with the injector wires and jumping the nuetral saftey switch I can give you a hand. Maybe we can do a little documentation. I know this has come up before. I havent done a writeup here yet. It seems like it would be a good one to do.
post #12 of 14 Old 06-03-2010, 10:53 AM Thread Starter
nickaldrich
Thanks.. ill have to take you up on that
post #13 of 14 Old 06-03-2010, 11:06 AM
Que89YJ
Clearout some space in your box and I can send you my info. or PM me yours.
post #14 of 14 Old 06-03-2010, 11:29 AM Thread Starter
nickaldrich
lol.. its done
transplant 2.5-4.0 rlmyers YJ Wrangler Technical Forum 2 10-14-2009 03:55 PM
heart transplant! e-tek TJ Wrangler Technical Forum 37 03-16-2008 05:33 PM
79 CJ to 95 YJ Transplant ? plasmacastor YJ Wrangler Technical Forum 8 09-09-2006 09:44 PM
89 XJ 4.0 transplant into 95 2.5L BackRoadJPin YJ Wrangler Technical Forum 13 03-17-2006 08:49 PM
97 4.0 xj for transplant>>$$1225.00 David K. YJ Wrangler Technical Forum 4 10-01-2004 02:13 PM
