1994 wrangler won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1994 wrangler won't start
The Ruffstuff 9" Disc Brake brackets!Even Better Heim Pricing! From RuffstuffPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 10-10-2013, 10:02 AM   #1
Bighaydn
Hey guys I'm new here but I've got a serious problem. I just bought a 94 yj it's beat up but runs great. But it wouldn't start the other morning. I figured dead battery so I charged it up and still nothing. Just a click when I turn the key. So next I bought a new starter relay an same thing. Next I bought a new starter and still same thing. I can push start it and it runs fine but it just won't turn over. I don't think it's my battery because my headlights and everything still work fine. Any thing helps thanks
Bighaydn is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 10:16 AM   #2
superj
1987 YJ Wrangler
you have a bad ground. check the engine one and the starter one. one should be right by the alternator and one attached to the starter. maybe a body ground is bad too so check those. dang, check them all, the ground is the trouble though
I don't feel like working on anything, at this time.
superj is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 10:22 AM   #3
Bighaydn
Sorry I'm a newbie this is my first jeep. So a bad ground? Should I find where it's at and sand it down?
Unread 10-10-2013, 04:44 PM   #4
Mark05059
remove the ground cable at the battery and clean it really good... do the same with the positive wire while your there... follow the ground to the opposite end and clean (sand) that end as well..
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 04:51 PM   #5
Apollo12227
Starter ground is the problem. Pretty much guarenteed.
You need to clean the batter terminals and inside the battery connectors. More importantly, there is a large ground wire going to the block, this needs to be removed from the block, cleaned with a wire brush, and reinstalled.
If this doesn't fix the issue, the cable may have turned to dust under the plastic cover.
Apollo12227 is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 05:03 PM   #6
Bighaydn
Thank you so much! I'll get right on it and hopefully get it to turn over
Unread 10-10-2013, 05:13 PM   #7
Apollo12227
Please post back if this fixes the issue. That way people who search the forum will know the resolution!
Unread 10-11-2013, 11:15 AM   #8
Bighaydn
I followed both the positive and ground wires and cleaned them real good. But when I turn the key it just buzzes at me now. So I hooked it up to jumper cables and it sounded like it was starting to turn over but it didn't have enough juice so I charged it all last night and now it just buzzes at me any ideas on what's going on? Maybe my battery is shot?
Unread 10-11-2013, 11:27 AM   #9
Duh
Hows the wire to the solenoid?
Duh is offline   Reply With Quote Quick reply to this message
Unread 10-11-2013, 11:56 AM   #10
Bighaydn
I figured it out. It was just my terminals on my battery replaced them and bam starts right up thanks for all the help!
battery issue , jeep , starter issue , wrangler
